884/885's or eibach @.85 on 5100's???
Discussion in 'Suspension' started by Fabulous, Aug 11, 2010.
  1. Aug 11, 2010 at 10:37 AM
    Fabulous
    Fabulous [OP] Well-Known Member
    Fabian
    Calgary, AB
    2006 Tacoma double-cab TRD Sport
    Homertaco grill, Light Racing UCA's, 2.8" front lift (5100's at 0.85 setting and Eibach springs) 2" AAL with rear 5100's, Wet Okole seat covers fr/ bk. 17 x 9 Incubus Crusher wheels w/ 4.5" backspacing. 30% tinted front windows.
    I just ordered some 5100's from DSMS, and I'm also going to do a 2" AAL in the back. My question is this... I just spoke with someone at Toytec, and he told me that I can't do the 5100's at .85 with the eibach coils, just the 0. He recomends the 885 OME coils at 0. I have a 4x4 double cab that sita 1" higher in the back now, and when I lift I want to keep the rake close to the same for when I have a load. I only want 2 ish inches of lift in the front because I don't want new UCA's, and I thought the 885's provide 2.5" without the top plate...this stuff is too confusing! Which way should I go? Anyone have the eibachs at 0.85? any pics? How about a double cab with 885's? pics? Any help is really appreciated, as I want to get this right the first time...
  2. Aug 11, 2010 at 11:18 AM
    erion109
    erion109 Well-Known Member
    Jayson
    Nashville
    06 TRD SPORT
    Weathertech FR & RR, DDM Tuning HID 55W 5000k Bi-Xenon, ARE topper, Yellow painted fog-lamp mod, anytime fog-lamp, Ipod interface, Red Top OPTIMA, Bilstein 5100s and 1.5 Toytech AAL, Redline Hoodstruts and EZdown tailgate.
    I'm in the same boat as you. I want to lift my truck 2.5 - 3". I've been looking at purchasing the 5100s, but unsure about coil springs and an AAL. I'm looking forward to see what tips you'll get. I would like my truck to sit level. I purchased a 3" ReadyLift kit, but have since decided to sell it (for a loss) and save up for the 5100s. I'll keep an eye out and see what comes your way.
  3. Aug 11, 2010 at 11:20 AM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    08 V6 4x4 DC TRD, 6spd
    TRD Supercharger, TRD CAI, Sirius, Rear TSB, Front 5100 with Eibach coils, 1.5" AAL, URD short throw, fog light mod, weather tech liners,
    I have 5100 set at 0.85 with eibach's. there are a few pictures in the suspension thread with this same set up from other members. ride quality is great, you can't go any higher than 0.85. setting at 0 will give you a smoother ride, although 0.85 setting is no where harsh.
  4. Aug 11, 2010 at 11:46 AM
    Fabulous
    Fabian
    Calgary, AB
    How much lift did you get with the eibach's and 5100's at .85? How's the alignment? Guy atToytec said he can't stop me from running the eibach's and 5100's at .85, but does not recommend it at all.
  5. Aug 11, 2010 at 11:48 AM
    stroM-
    stroM- @alteregoadventure
    Santa Rosa, California
    2006 4X4 TRD OR
    If you want a full 3 youll have to go 885's w/5100's set at .85
    or
    you can go 885's w a 1/4 top plate and 5100's at 0
  6. Aug 11, 2010 at 12:00 PM
    Fabulous
    Fabian
    Calgary, AB
    I don't want 3...2.5 at the very most...2 exactly would be ideal.
  7. Aug 11, 2010 at 12:03 PM
    stroM-
    2006 4X4 TRD OR
    then 885's with 5100's at 0 - the 885's provide 1.75 of lift. so realistically youll be around 2.25-2.5 with that setup.
  8. Aug 11, 2010 at 12:12 PM
    Fabulous
    Fabian
    Calgary, AB
    I thought the 885's provided more like 2.5-2.75, at least that is what I have read on here...?!
  9. Aug 11, 2010 at 12:15 PM
    stroM-
    2006 4X4 TRD OR
  10. Aug 11, 2010 at 2:41 PM
    Fabulous
    Fabian
    Calgary, AB
    Anyone else? I think I'm stuck on trying the eibachs at 0.85 unless someone else has something else for me to consider...
  11. Aug 11, 2010 at 3:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The 885's will give close to 3" lift without any spacers, and at the 0" setting on the bilstiens. Wheelers site is in correct.
  12. Aug 11, 2010 at 3:30 PM
    Fabulous
    Fabian
    Calgary, AB
    Thanks Chris. What would you suggest? I see that your like the guru around here.
  13. Aug 11, 2010 at 4:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The 885's will give you close to 3" lift (2.75 to 3") with the billies at the 0" setting, or you can get the Eibach 1.6" lift springs, and use the bilstiens at the .85" setting. Both will ride about the same.
  14. Aug 11, 2010 at 4:48 PM
    Hipster
    Hipster Nothing beats a Butter Shave..
    Tom
    Tucson
    '10 DC trd 4x4
    Billy's @ .85 w/ Eibachs front, TSB w/ 5100's rear + 1.5" AAL & shims, Debadged, Avid Bolt On Sliders, NFab Light Bar w/ (2) Lightforce 170's. Weathertechs, ATO bed bars.
    I'm not sure who you were talking to at Toytec but:
    1. When I talked to them and told him what I wanted to do, he recommended the Eibach w/ Billy's set @ .85 which I put on two days ago, looks great and with the TSB is near level, (a slight bro or Yuma rake but that'll be gone in a month with I do the 1.5 AAL)
    2. Not too long ago there was a Toytec group buy and in that post it stated that you could do a "0" or a ".85 with the Eibachs but nothing higher.
    3. My truck aligned perfectly. Today I drove to Sacaton, AZ and back to Tucson @ 75-80 MPH. Perfect ride. Around town I think it even feels better than stock. Lift ended up being around 2.5" or so but it may settle a bit.
    Hope the info helps out.
    hip
  15. Aug 13, 2010 at 9:50 PM
    Fabulous
    Fabian
    Calgary, AB
    What AAL did you go with? Any pics. I'm so stuck here it hurts. I keep pondering 884/885 or eibachs at 0.85. I just want to order and be done with this.
  16. Sep 15, 2010 at 2:23 PM
    huntark03
    huntark03 I'd rather be hunting!
    Maumelle, AR
    2005 Limited Tundra DC 4X4
    Spidertrax Wheel Spacers aFe Pro Dry Drop in Air Filter Weathertech Liners Bilstein 5100s w/ OME 885 coils and ToyTec 1.5" AALs Light Racing UCAs
    subscribed!!
  17. Sep 15, 2010 at 2:42 PM
    huntark03
    Maumelle, AR
    Would love some pics of your setup with the AAL installed!! :)
  18. Sep 15, 2010 at 3:57 PM
    Fabulous
    Fabian
    Calgary, AB
    I'm getting an alignment on Friday, and I'll snap some photos right afterwards, cool? It's been a week since install, and the rear 2" AAL is still at about 2.3" from stock, and the front is just over 2" from stock...like around 2 1/8-2 1/4". I'll double check tonight. I think it looks good, and rides nice even with my alignment being way off.
  19. Sep 17, 2010 at 11:31 AM
    huntark03
    Maumelle, AR
    Hey Hipster,
    Did you ever add that 1.5 AAL? I'd love to see pictures!!!:D
  20. Sep 27, 2010 at 6:47 AM
    huntark03
    Maumelle, AR
    Anybody else have pics of this setup?
