884 OME Question
Discussion in 'Suspension' started by big hunter, Dec 11, 2009.
  1. Dec 11, 2009 at 7:16 PM
    big hunter
    big hunter [OP] Member
    PA
    TRD
    Just wondering if anyone is running 884 OME Coil Springs from the kit from Toytech? If so can I run this kit with stock shocks? Would the 884 coil springs be enough for the access cab to give me a full 3 in.?
  2. Dec 11, 2009 at 7:36 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    I have the 884's on my double cab 4x4 with TRD shocks. I have been parked next to numerious tacomas with 3" of lift and notice no real difference.
  3. Dec 11, 2009 at 7:39 PM
    big hunter
    PA
    TRD
    Did you install the lift? Do I need to use spacers on top of the coils? Would the truck be able to be driven before an alinement?
  4. Dec 11, 2009 at 7:43 PM
    Tacoma831
    Tacoma831 Member
    Santa Cruz, CA
    08 Tacoma Sport 4x4
    OME 886 Coils, OME Shocks, OME Dakars, Snug Top, De-Badged, ARB Bullbar, XRC8 Winch
    I have 884's on my stock shocks with an access cab and it rides a little stiff.
  5. Dec 11, 2009 at 7:57 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    I left that out, certainly need the spacers for the full 3" of lift. They should come with the kit. I did install mine myself and I drove without an alignment for quite a few months with no issues. My tires wore fine and I had no wondering on the road, every vehicle will be different. If you buy the kit from Toytec you should get all you need. Not to mention feel free to ask them any questions as I found them very helpful.
