884 or 885 coils?
Discussion in 'Suspension' started by jdkeller, Dec 7, 2008.
  1. Dec 7, 2008 at 11:39 PM
    jdkeller
    jdkeller [OP] How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    I will be purchasing a 3inch lift from toytech with the spacers up front, long add a leaf in the back, and front coils. I have an 08 dc prerunner. Is it better to buy the package with the 884 coils or the 885 coils? I do not have a winch or anything like that and will not be adding one so there is no additional weight up front. I mainly drive on road but will use the truck for off road 10-15 percent of the time so i want a nice smooth ride. Thanks for the help!
  2. Dec 7, 2008 at 11:46 PM
    alexamado
    alexamado TEXMEX TACO
    TEXAS
    2006 PRERUNNER TRD SPORT
    885 OME Coils w/ OME N140S Shocks, Rear TSB w/ Rear AAL, Rear 5125 Bilstein Shocks, Westin Ultimate Bull Bar w/ KC Slimlites, Westin Running Boards, Roll n Lock Retractable Bed Cover, AVS Bugflector II
    I got 885's on mine and works great. I've been told that 885's are better for double cabs even if you don't have a winch up front. I also got the OME coils and the ride, IMO, is the same if not slightly better then stock.
  3. Dec 8, 2008 at 9:55 AM
    TacoTycoon
    TacoTycoon Well-Known Member
    Justin
    Hayes, VA
    07 TRD Sport 4WD Indigo Ink
    Bilstein 5100 Coilovers, Diff Drop Kit, TSB AAL, 285/70/17 BFG A/T Tires, 17X8 Helo HE835 Wheels, Rear Bilstein 5100s, Dual Flowmaster 50 series, TRD CAI, TRD Front Seat Covers, Rear Suspension TSB, 35% Tint, Redline Hood Struts, MagLite Mod
    yeah Double Cabs should use 885 coils to attain the full 3in of lift in the front
  4. Dec 8, 2008 at 10:19 AM
    TacomaYAK
    TacomaYAK The Reel Sportsman
    League City, Tx
    08 Access Cab 4.0
    Lifted.
    I have the 885's on my Access Cab..
  5. Dec 8, 2008 at 11:05 AM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    Go with the 885's for the double cab even if you're not adding weight up front
  6. Dec 8, 2008 at 12:48 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Ok i appreciate the responses. Ill go with the 885's then. 32" mud terrains would fit right? Because I know most people talk about wanting 33's but i dont want to do any cutting.
  7. Dec 8, 2008 at 5:13 PM
    TacoNut
    Adam
    Denver, Co
    You'll probably have to remove the front mudflaps.... might still be a little bit of rub but you should be close
  8. Dec 8, 2008 at 5:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    With the OME 885's and 32's, you should have no rubbing.
  9. Sep 6, 2009 at 9:12 AM
    TSer
    TSer Member
    06 Tacoma
    I put the 884's in my double cab. After settling it lifted it about 1.25 inches. If you are after lift, go for the 885's. The ride with the 884's and n140s shocks is super smooth. I'm happy with it and there isn't as much stress on the drive and spension components, compared with 885's. I'm sure I could run 32's if I wanted.
  10. Sep 6, 2009 at 9:55 AM
    ilovetacos
    ilovetacos Well-Known Member
    Gavin
    Sacramento/Woodland
    2006 TRD Sport 4x4 DC
    Sold!
    I have the 885 coils and my 32" Mud Terrains do not rub at all unless I stuff them really good. The 885's paired with a 1/4" top plate spacer provided me about 2.5" of lift because my 885 coils settled after about 3 months.
  11. Sep 6, 2009 at 1:19 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Thanks. I bought the 885's a while back and ran them. They were great. Since then I upgraded to fox coilovers.
  12. Sep 10, 2009 at 11:56 PM
    Redfox458
    Redfox458 Well-Known Member
    07 Tacoma TRD Sport Access Cab
    So if I get some 885s with the 1/4" spacer, should I do a transfer case drop and use 5100s?
    The issue with me is that I have a stock setup with the rear TSB. I need tires after 22k miles of the Dueler H/Ts. Wet weather is approaching and I need something beefier. I'd hate to throw some nicer A/Ts on there and then lift it later and realize I could have gone with a bigger tire. All at the same time, I cant afford a huge amount of stuff. What's the best deal for the least amount of money?? Should I also consider the rear AAL TSB spring since the back sits exactly 3" higher?
  13. Sep 11, 2009 at 12:08 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    You can get the 885's but I would use the OME shocks instead of the billys. Transfer case drop??? Do you mean differential drop? Only do it if you end up needing it. I ran the front OME lift and rear tsb springs and fit 285/75/16's.
  14. Sep 11, 2009 at 9:48 AM
    Chickenmunga
    Chickenmunga Nuggety
    Hillsboro, Oregon
    08 TRD Offroad DC 4x4 (read the build)
    Is there a point when you need to step up to 886? I'm trying to get a visual.
  15. Sep 11, 2009 at 2:43 PM
    Redfox458
    Yes, I meant differential drop...you get kind of silly after 35 hours with no sleep :p
    You ran front OME lift (coils and shocks), and JUST the rear TSB springs? Thats my ideal setup...maybe some airbags in the rear for when I tow
  16. Sep 11, 2009 at 4:40 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    You get the 886's if you plan on adding weight to the front like an offroad bumper and/or winch.
    Yes I bought it without an aal. I wanted to see first how I liked the stance. Front was about 1/4" higher than the back. Oh, and I wasnt running the 1/4" spacer up front. But after some offroading and crazy flexing, the tires would rub the front of the rear fenders. So I got an All Pro 3" leaf pack setup. Now my rear is like 3/4 to an inch higher. Just depends on what you want and if you offroad.
  17. Sep 12, 2009 at 7:34 PM
    Redfox458
    Ok so I am going to get TOTALLY flamed here for saying this...but whatev. I have my 2007 TRD sport access 6spd 4X4, bought it new in June of '07 and haven't wheeled it once....with the exception of it being in 4 wheel for a week during the snow storm in Portland last year. With that being said, I'd like to do some light wheeling (nothing too serious, its my every day driver), plus I haul my quad and a trailer from time to time. So this is the lift I was thinking:
    OME 885 coils with top plate spacers (for full 3" lift)
    Front Bilstein 5100 series shocks set at 0
    OME N182 Rear shocks (seem to be a better deal for the $$)
    1 1/2" AAL w/TSB rear springs
    Total: $678.96.....ouch, guess you get what you pay for...
    Do you think I'll need the differential drop, or UCAs?? I'm almost at my limit of spending, especially for almost $1,000 in tires too....
    I wanted to get the rough country 3" lift on my truck, but figured that there was a reason everybody was going with the OME instead....
  18. Sep 12, 2009 at 8:25 PM
    Redfox458
    Ok....so how about instead I get the OME suspension lift kit from toytec? Seems like I pay a little more and get ALL OME. Will they substitute the 1 1/2" rear leafs for the TSB ones? Or should I just get the block in the back? GRRRRRRR too many options!
  19. Sep 13, 2009 at 12:41 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Get the tsb aal if you have the tsb done. they will gladly substitute. Also, new uca's are required to correct alignment issues but are not necessary.
    If you want to spend less, get the 5100 bilsteins all the way around and set the front ones for 2.5" of lift. Then no new uca's! If you arent doing a lot of offroading this will work fine.
  20. Sep 13, 2009 at 1:12 AM
    Redfox458
    Do you think if I get all new bilsteins with the front set at 2.5, and then get the AAL for the TSB in the rear, that it will look bad? I just know that with my quad in the back as of now, it sets perfectly level. I'd like to keep that stance, only a little bit higher....
