884 - TSB AAL - DC LB 4x4
Discussion in 'Suspension' started by NLF, Feb 26, 2011.
  1. Feb 26, 2011 at 12:34 PM
    NLF
    NLF [OP] Well-Known Member
    Levi
    Minneapolis, MN
    '11 TRD Sport DC LB 4x4
    OME 884 & Bilstein 5100s @ 0, TSB Rear w/5100s, 20x8 Mamba M2 275/55/20 Geolander, Access Cover
    Ok guys, I am going to post this up so that others can see the results.
    2011 DC LB 4X4 TRD SPORT
    Front: OME 884 w/ 5100 @ zero
    Rear: TSB Springs with Toytec 1.5" AAL
    OME Carrier Bearing Drop
    2.5" of lift in the front with no spacers. Great ride, small vibe at 35-50 mph until I installed the OME carrier bearing drop kit. Now it is all good, no vibes.
    I had 5100 at 1.75" on stock shocks before this, and to me this set-up is much better, and higher.
    Let me know what you think.
  2. Feb 26, 2011 at 12:39 PM
    MX81
    MX81 Well-Known Member
    Dallas
    2014 TRD Offroad PreRunner
    Looks great, aftermarket UCA's ? What were they able to get your front alignment spec to?
  3. Feb 26, 2011 at 12:43 PM
    DocCisco
    DocCisco Well-Known Member
    David
    Utah County, UT
    LB TRD Sport 4x4
    I like the look! Debating on doing something similar with mine in the coming months, such a noob though, still need to learn about suspension.
  4. Feb 26, 2011 at 12:43 PM
    NLF
    Levi
    Minneapolis, MN
    Alignment is Monday so I will post numbers. Stock UCAs.
  5. Feb 26, 2011 at 12:44 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Looking good .
    DCLB FTW .
  6. Feb 26, 2011 at 12:45 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    looks really good man.....
  7. Feb 26, 2011 at 12:47 PM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    Awesome! Been debating this setup with 1" block instead of AAL for mine
  8. Feb 26, 2011 at 5:46 PM
    elwood
    elwood "Really, how hard can it be?" Jeremy Clarkson
    Neal
    ont, canada
    2007 SR5 4x4 LB
    K/N cold air intake, leer cap, running boards, nose gaurd,E brake control, mud flap cut, suspension tsb, Rear diff breather mod,Factory Fog lights, Factory front diff cover
    This is all i'm waiting for. Have pm'd dylan allready and will order in the next few weeks. I'm staying with the ome shocks tho.
    Cheers and LOOKIN GOOD!!!!!!!!!!!!!!!:cool:
    ps you running spacers on those wheels?:D
  9. Feb 26, 2011 at 5:56 PM
    NLF
    Levi
    Minneapolis, MN
    Nope, XD Revolvers 17x9 with 4.5" backspacing (i believe)
  10. Feb 26, 2011 at 6:00 PM
    elwood
    Neal
    ont, canada
    2007 SR5 4x4 LB
    Just sent some rep your way, thanks again
  11. Feb 27, 2011 at 11:42 AM
    Tythias
    Tythias Active Member
    NLF can you post a pic of your inner/outer CV angles with this lift?
  12. Feb 27, 2011 at 11:56 AM
    qwertypepper
    qwertypepper Well-Known Member
    cam
    canada
    2011 TRD sport dclb
    i think this is exactly what im going to do. do you think i could fit some 255/80/17 in there, with proper backspacing?
  13. Feb 27, 2011 at 11:59 AM
    plee33
    plee33 Well-Known Member
    Peter
    Sacramento, CA.
    SWB TRD Sport Long Bed 4x4
    SnugTop SuperSport Shell, BedRug, OME Heavy Duty Lift Kit, Weathertech Liners, more to come....
    I'm going with 886s. Hopefully all goes well.
  14. Feb 28, 2011 at 9:53 AM
    NLF
    Levi
    Minneapolis, MN
    alignment rescheduled to Thursday, FYI.
  15. Feb 28, 2011 at 9:57 AM
    mfrantz24
    mfrantz24 Member
    CT
    2011 DC LB Sport
    That's a great looking truck. Any chance you can post some measurements from your hub centers to your fender for reference? Thanks!
  16. Mar 1, 2011 at 4:47 PM
    09slvrtaco
    09slvrtaco Well-Known Member
    Rancho Cucamonga
    09 Silver DC LB PreRunner Sport
    Banks Monster Exhaust, Weather Tech's, Tint, AFE air filter, 5100's on all four corners, front set at 0, Eibach coils, tsb spring
    x2 - I'd like to know what the measurements are too? Looks like you got a little rake but I like it. How does it ride with the tsb + aal?
  17. Mar 2, 2011 at 9:26 PM
    Tacodog
    Tacodog Well-Known Member
    Ron
    Renton, Wa.
    ‘19 TRD offroad DCSB Cement
    Icon stage 1, Icon upper control arms, 17” Fuel wheels,Ridge Grapplers, TRD exhaust, leather interior.
    Nice. That's the same set up I am planing to go with.
  18. Mar 3, 2011 at 12:32 PM
    NLF
    Levi
    Minneapolis, MN
    Sorry guys, I had alignment done and they did it wrong.
    Camber - L=2.0 R=2.0
    Caster - L=.1 R=(-.03)
    Toe - L=0 R=0
    They mixed up the Camber and Caster setting, and it took them 1.5 hours to do. I was in a hurry and didn't catch until I got back to the office. I am having redone tomorrow am, and I will reply back with good numbers and lift height numbers.
  19. Mar 4, 2011 at 5:41 AM
    intense
    intense Well-Known Member
    Georgia
    TRD OFF ROAD '07
    ASE Dry, Carbon filter removed, Grillcraft, 5100's. Low Pro Ameriweld box black powder. Tint / Vent Visors. Textured Black skid plate. Husky Liners. Design Seat Covers
    U got 2.25 front lift with 884's only ? Did ride un-stiffen any ? On install U need extra spacers or other parts ?
  20. Mar 4, 2011 at 10:39 AM
    NLF
    Levi
    Minneapolis, MN
    Just back from alignment shop today.
    Camber - L=.4 R=.4
    Caster - L=1.6 R=1.5
    Toe - L=.02 R=.01
    Stock UCA, rides fine. Will pull in rutted lanes, but it did that before with the wider wheels.
    Lift Heights: 884 with no spacers - 5100 at 0 in front - from center of hub
    front 22.5"
    Rear 24"
