884's and lift?
Discussion in 'Suspension' started by TacoSupreem, Mar 18, 2010.
  1. Mar 18, 2010 at 12:51 PM
    TacoSupreem
    TacoSupreem [OP] Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Just wondering how much lift you guys are seeing with the 884 ome coils with no top plate spacer? Please specify whether you are a 4wd or prerunner. Thanks
  2. Mar 18, 2010 at 12:55 PM
    bigburrito
    bigburrito Local Man
    DuPage County
    '09 TRD OR
    Demello sliders, fog lights anytime, 265/75R16 Duratracs, 60" HiLift, VIAIR OBA 2.5 gallon tank, FM Super 44, TSB springs, 5100s at .85, bent tailgate
    how much lift did you see? says in your profile you already have the 884s.
    ive got the same question, but am looking more at the 885s
  3. Mar 18, 2010 at 1:48 PM
    TacoSupreem
    Hayden
    Kentucky
    I have them but they are still in the box. The 885's are giving prerunner's 3" and 4x4's 2.5" so I've heard.
  4. Mar 19, 2010 at 7:27 AM
    bigburrito
    DuPage County
    '09 TRD OR
    interesting. are you looking for more concrete lift #s before you do the install? are you trying to get to a certain #? id be interested to see how those 884s work out for you considering we have nearly identical trucks
  5. Mar 19, 2010 at 7:35 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    this is off of wheeleroffroad.com
    OME 885 Tacoma Front Coil Set: 153.00/pr
    Provides approx 1.75" lift on stock Tacoma's.
  6. Mar 19, 2010 at 7:37 AM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    I thought Wheelers site was wrong. People are getting close to 3" with the 885's if I am not mistaken.
  7. Mar 19, 2010 at 7:42 AM
    TacoSupreem
    Hayden
    Kentucky
    ^^^yeah, just tryin to decide whether or not to put these on or sell them and get the 885's? For some reason toytec recommends the 884 for access cabs? So I went ahead and bought them only to find out later that the 885's are the same spring rate only they give a little more lift? I'm just wanting a 3" lift, but I don't wanna use a top plate spacer unless I have to. I want to get as much of the 3" as possible with the coils. Does that make sense?
  8. Mar 19, 2010 at 7:43 AM
    bigburrito
    DuPage County
    '09 TRD OR
    that 1.75" hypothetical lift height doesnt specify engine or body style though
    only difference between 884 and 885 is 10 mm in length, spring rates remain the same. this 10mm would translate into nearly .8 inch lift difference if you follow the spacer formula. spacer height x 2 = lift height. dont quote me on this but from what ive read my guess-math should at least be close
  9. Mar 19, 2010 at 7:49 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I think your right, the 884 is for the acc cabs and the 885 are for dbl cabs.
  10. Mar 19, 2010 at 7:52 AM
    rb11701
    rb11701 Oh yeah!
    Rob
    If I am not mistaken, the top plates are needed for a full 3" of lift. If you sell those 884's, let me know. I am in the market for a set.
  11. Mar 19, 2010 at 7:54 AM
    bigburrito
    DuPage County
    '09 TRD OR
    well if you want closer to 3" im thinking you should def go with the 885s at a minimum.
    the more i think about it, ill probably go with the 885s. i have sliders which are about 100 pounds, and am putting on a beefier skid plate in the future. i only want ~2 inch lift so i dont have to mess with UCAs or worry about my CV angles. the extra weight of the DC would be equaled out on my AC by the sliders/skids.
  12. Mar 19, 2010 at 8:06 AM
    TacoSupreem
    Hayden
    Kentucky
    If yOu look on ome/arb's website it shows the 885?
  13. Mar 19, 2010 at 8:09 AM
    TacoSupreem
    Hayden
    Kentucky
    I know chris4x4 said he got a full 3" of lift with his dc prerunner? So me being an access cab 4x4 wouldn't that be about equal?
  14. Mar 19, 2010 at 8:09 AM
    TacoSupreem
    Hayden
    Kentucky
    With the 885's^^^
  15. Mar 19, 2010 at 1:51 PM
    bigburrito
    DuPage County
    '09 TRD OR
    i went searching around on customtacos, ttora, and toyota nation and believe i am coming closer to the answer we are looking for.
    AC with 884= 2" lift
    AC with 884+.5"spacer= 3"
    AC with 885=2.5-3" lift
    Measurements on DC from center of wheel to bottom of fender flare (might help us?) if only we could find these same measurements for an AC
    885 no spacer = 23"
    885 w .5" spacer = 24.25"
    now i am leaning more towards the 884s..... i wish it wasnt such a pita to swap out springs or i wouldnt be nearly as indecisive
  16. Mar 19, 2010 at 2:08 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    If you get your own spring compressor it doesn't seem that bad to do.
  17. Mar 19, 2010 at 2:12 PM
    bigburrito
    DuPage County
    '09 TRD OR
    no, its not a difficult job by any means, just a general pain to have to do all the work twice, go get it aligned again, etc
    "anything worth doing is worth doing right the first time"
  18. Mar 19, 2010 at 2:36 PM
    TacoSupreem
    Hayden
    Kentucky
    I measured my 884's and they are 15.25". I think the stock springs are 14"?
  19. Mar 20, 2010 at 8:40 AM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    You would think you would see about 2.25 to 2.5 inch's of lift.
  20. Mar 21, 2010 at 3:55 PM
    huff.jeremy
    huff.jeremy Well-Known Member
    Illinois
    2010 MagGray SR5 Access Cab, 4x4, 2.7L, 5spd
    OME 884's, OME shocks, Wheelers 1.5" AAL, Light Racing UCA, Jason Fiberglass top, URD Short Shifter, Fog Lights
    Does anyone know how much more lift a 2.7L would get compared to a 4.0L with 884s? (truck: Access cab 4x4 2.7L)
    I definitely DONT want to end up having over 2.5 inches of lift because of a lighter motor.
