885 0r 886 coil ome lift?
Discussion in 'Suspension' started by MurphyZ, Jan 16, 2010.
  1. Jan 16, 2010 at 7:15 AM
    MurphyZ
    MurphyZ [OP] Well-Known Member
    I HATE SPICYTACOS
    Alaska
    97 4runner, 08 Tundy
    89 SAS 3.4 1st gen 4runner- Sold 3.4 swap cut hood for clearance exhaust x-over and magnaflow muffler lockright in the rear SAS 83 toy axle (Wab-Fab) 4xinnovations sliders roof rack from 2nd gen for kayak.
    i need to know which will i need in the ome lift.
    09 dc 4x4 sport
    want:
    front a little higher in front then in back
    nice ride (will the 886 coil be too hard or stiff)
    going for add a leaf in back( 1.5 or 2"?)
    thanks in advance
    Murphy
  2. Jan 16, 2010 at 7:20 AM
    MurphyZ
    I HATE SPICYTACOS
    Alaska
    also do i need the axle shims for a 1.5 add a leaf?or just for the 2".
  3. Jan 16, 2010 at 7:28 AM
    misterquad
    misterquad Well-Known Member
    I suggest calling Wheelers or Jacque at TRDparts4U. They both have lots of experience with lots of trucks and their setups. They can tell you exactly what you need and give great prices. Both are very friendly and willing to talk.
  4. Jan 16, 2010 at 7:30 AM
    MurphyZ
    I HATE SPICYTACOS
    Alaska
    where do i find their numbers?
  5. Jan 16, 2010 at 7:44 AM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    I would say the 886 would break your teeth if you don't have a aftermarket bumber on the front. 885's will give you roughly 3" of lift in the front. That sounds a bit too high from your original post. Look into the 884's (same spring rate as 885 but ~1" shorter. You can try with stock shocks or upgrade to either Bilstien 5100's or OME Nitro shocks. (more money) You can put in for the TSB for the rear leafs and pick up a inch or so on the rear. IMO, this is the best mini-lift for the buck. Eibachs would yields around the same hieght, perhaps a tad higher due to it being a 620# spring vs 590# for 884 and you having a DC (more weight on the front).
    With 885's comes almost 3". At that height new UCA should be in the back of your head as should be a AAL for the rear. And upgraded shocks front/rear. Now comes tires and perhaps rims. Alot of cash going down that road IMO. If budget is not an issue I say go for it. If you are looking for just a little more agressive stance think about the other option.
  6. Jan 16, 2010 at 1:31 PM
    MurphyZ
    I HATE SPICYTACOS
    Alaska
    im going for a final lift in the front of 3 inches
    2.5 in the rear
    going to do the ome complete lift i think. i think that the 885 will fit my purpose. are the shocks that they put in that set any good?
  7. Jan 16, 2010 at 1:45 PM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    Are you talking about the OME shocks or are you just getting the coils? :confused:
    And yes the OME shocks are the best bang for your buck.
    And the 885's will suit your purpose just fine.
  8. Jan 16, 2010 at 1:48 PM
    Klipp11
    Klipp11 s3
    Kevin
    '06 DC 4x4 LB
    OME 885 coils, Bilstein 5100 shocks, 1.5" AAL, TC uca's, cab mount chop, 5000k HID heads and fogs, LED tails, satoshi GC w/ Hella 500's mounted behind it with 5000k HID upgrade, Extang solid tri-fold tonneau cover, Yakima roof rack, fog light anytime mod, disable a/c defrost mod
    i went with the 885 coils on my double cab long box with billstein 5100's all around. this setup works great. also added some total chaos upper control arms to ensure proper alignment. it adds up, but it's done right. chris 4x4 is running the ome shocks and says they run great too. you might want to add the 1/4" spacer from toytec on the driver side to level out the front end.
  9. Jan 16, 2010 at 3:17 PM
    MurphyZ
    I HATE SPICYTACOS
    Alaska
    why tc uca and not light racing uca?
  10. Jan 16, 2010 at 3:22 PM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    17 DCSB Silver Sky
    885 and LR UCAs are fine. TC do just a little bit more from what I've read.
  11. Jan 16, 2010 at 5:37 PM
    misterquad
  12. Jan 16, 2010 at 11:30 PM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    Icons, Bilstein 5100, Rear Leaf TSB, 17x9 American Racing Chamber Teflon, 275/70/17 Goodyear
    Well if you want the front higher you better not lift the rear 2 inches, lol. It is already 1.75 inches higher, then you willl lift it more to 3.75 inches.....You would then need spindles to sit higher in the front.
  13. Jan 17, 2010 at 12:28 AM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    I would say get the 885's with the ome front shocks. Use the 1/4" front spacer in the front as well and put the trim packer on the drivers side shock. Then in the rear do a 1.5" aal with one shocks. Will ride great and the front should be a tad bit higher.
    If your wanting the front a lot higher just getsome tsb leafs instead of doing the aal.
