885s I can't sell and new 5100 I just received????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by solus, Aug 12, 2009.
  1. Aug 12, 2009 at 9:10 PM
    #41
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    No.
  2. Aug 13, 2009 at 9:47 AM
    #42
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    so should I also install the top plate spacers?
  3. Aug 13, 2009 at 9:49 AM
    #43
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Depends on how much lift you want. I would leave them off, and install them latter if the springs sag. UNLESS you are installing them on the 5100's set at .85" lift.
  4. Aug 13, 2009 at 9:53 AM
    #44
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    NNNNNOOOOOOOOOO!!!!
    your going to get more than enough lift out of the 885s and 5100s at .85, dont push it any more. you will already loose much of your downtravel. if you want more, then you will need a drop bracket if your 4x4 or spindles if your a prerunner.
  5. Aug 13, 2009 at 9:54 AM
    #45
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    DOH!!!! Didnt know he was setting the 5100's at .85" lift.....:eek:
  6. Aug 13, 2009 at 10:59 AM
    #46
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    I'm setting the shocks at 0... I'm not going to put the spacers on... just the coils will give 2.5 inches of lift right.. with 5100s at 0 right?
  7. Aug 13, 2009 at 11:00 AM
    #47
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes. Maybe closer to 3" lift. With the shocks set to 0" lift, you should be fine addint the top plate spacer down the line if the springs settle, but consider an aftermarket UCA if you do this.
  8. Aug 17, 2009 at 5:04 PM
    #48
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    well its done... 885 w/o spacer, 5100s at 0, and rear tsb plus tsb aal
  9. Aug 17, 2009 at 5:04 PM
    #49
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Looks good!
  10. Aug 17, 2009 at 6:38 PM
    #50
    yosh2000
    CO
    '17 Tundra CM 5.7
    cool man, looks good.
    may i ask, what size tires? 285s? also, you did the aal from wheelers correct? reason i ask, im looking at getting one of those or the 3 pack, cant decide and i'de like to see a pic of each. thanks.
  11. Aug 17, 2009 at 6:51 PM
    #51
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    Actually they are 265's because I got them before I got the lift... and its a toytec aal meant for tacos with the leaf spring tsb done
