885x and billies, hub to fender measurements.
Discussion in 'Suspension' started by Raceline08, Apr 27, 2013.
  1. Apr 27, 2013 at 7:36 PM
    Raceline08
    Raceline08 [OP] Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    Ok everyone I need your help, today I tried to install my 885x and billies set a 0 with the top plate spacer and it wouldn't fit. The whole assembly was too long , I couldn't get the bottom shock bolt in the shock on the lca, I tried and banged etc. had my bro to help and we just couldn't do it.
    I want to run the top plate spacer and the spacer for the taco lean but I'm curious of what you guys run. I'm currently at drivers side front at 22.5 inches and on the passenger side 23.5 inches. ( I put the stock shocks and springs back on with the revtek spacer. Bought it that way )
    If I took the spacer off the assembly would fit I believe but it was getting late and I still had to do the passenger side. Any help would be great.
    I would like to see fellow TW members measurements hub to fender without the top plate spacer.
    Thanks,
    Brett
  2. Apr 27, 2013 at 7:46 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Im at 23" hub to fender up front with 885s and OME shocks. Can you elaborate on how they didn't fit? I am guesing you did not loosen the LCA bolts, what method did you use? Remove spindle from UCA and move sway bar? Did you have the eye of the shock in place but just couldnt get the bolt thru? If thats the case wedge something under the eye and pry the shock up until you can push the bolt through
  3. Apr 27, 2013 at 7:48 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    I'm at 22 1/2 with 885x , OME shocks , no top plate spacer on my DCLB 4X4
  4. Apr 27, 2013 at 8:08 PM
    Raceline08
    Brett
    Santa Rosa, ca
    I did the install meathod to the tee of the sticky on the 2nd gen ome lift here on TW . Sway bar removed,lca bolts removed. I didn't do the UCA cause I thought it wasn't nessary.? And I don't want to get a alignment again, but if it is them I will. The shock eye was lined up but just couldn't get the bolt in, I wedged and pryed etc.
    Thanks,
    Brett
  5. Apr 27, 2013 at 8:20 PM
    Raceline08
    Brett
    Santa Rosa, ca
    Thanks, Oz . Well if your at 22.5 with no spacer then it really wouldn't matter if I ran the top plate spacers cause that's what I'm measuring on the drivers side.
    You 22.5 on both sides? Was thinking I could run the 1/4 inch spacer for taco lean on the driver side and no spacer on the passenger side. Are you using the spring isolators between the spring and the top plate? My crappy revtek didn't have those cause the spacer has cut outs for the top plate studs. I have the isolators now which I was not aware of that I needed to protect the studs.
    Thanks,
    Brett
  6. Apr 27, 2013 at 8:22 PM
    OZ-T
    Peter North
    British Columbia
    I have the 5mm OME trim packer on the driver's side for taco lean , yes I'm the same height both sides
  7. Apr 27, 2013 at 8:32 PM
    Large
    Large Red
    If you mod your suspension at all I would recommend an alignment.
  8. Apr 27, 2013 at 8:40 PM
    Raceline08
    Brett
    Santa Rosa, ca
    Thanks Oz ! Gotcha, do you have the isolators?
    Thanks,
    Brett
  9. Apr 27, 2013 at 8:42 PM
    OZ-T
    Peter North
    British Columbia
    Not sure what you mean by isolators , you mean the rubber ring above the coil ?
  10. Apr 27, 2013 at 8:43 PM
    hualampeter
    hualampeter Well-Known Member
    Peter
    San Jose
    TRD Off Road
    Banks Monster Exhaust, DTLT, BLK Headlights, Alpine Head Unit w/ Alpine Amp, Image Dynamics Speakers. 10" Subs on backwall!
    you might need to use a jack to give you room to install your shocks. I had to use it.
  11. Apr 27, 2013 at 8:49 PM
    Raceline08
    Brett
    Santa Rosa, ca
    Yes sir. Do you have that?
    Brett
  12. Apr 27, 2013 at 8:49 PM
    OZ-T
    Peter North
    British Columbia
    Yes
  13. Apr 27, 2013 at 8:50 PM
    Raceline08
    Brett
    Santa Rosa, ca
    I tried that also. No luck
    Brett
  14. Apr 27, 2013 at 9:08 PM
    Raceline08
    Brett
    Santa Rosa, ca
    Perfect, now I know what I have to do!
    Thanks,
    Brett
  15. Apr 27, 2013 at 9:11 PM
    Raceline08
    Brett
    Santa Rosa, ca
    Oh ya, the spring compressor I borrowed from o Riley auto parts was a bitch. Crank crank crank, damn my hands hurt. Those things are dangerous for sure, but worked.
    Brett
  16. Apr 27, 2013 at 9:13 PM
    mjm540ii
    mjm540ii Ding Dang Dee
    Oxford, PA
    2010 TRD Sport AC V6
    Fog light mod, interior LED's, illuminated switch, B110 5100's in the rear, Satoshi Grill, Hella 500's, 4X Innovations sliders, rear diff breather mod, painted rocker panels, bhlm, yellow wire mod, CB, Wheeler's 2"aal, Allpro diff skid, ubolt flip, LR UCA's, 885X's w/ 13mm spacer on 5100's, Spydertrax spacers, Relentless IFS/ mid/ T case skids, 255/85/16 KM2s, block heater, DTRL mod, T2 eyelids, Wheelers Superbumps, Extended SS brake lines, ATO shackle flip kit,1" 4Crawler BL, Elite fr plate bumper, Flyzeye LEDs, Drilled and slotted rotors, 20" LED bar
  17. Apr 27, 2013 at 10:19 PM
    Raceline08
    Brett
    Santa Rosa, ca
    Ill post when done
    Brett
  18. Apr 28, 2013 at 3:05 AM
    mjm540ii
    Oxford, PA
    Remember not to tighten any control arms (if loosened) till the truck is on its own weight!
  19. Apr 28, 2013 at 5:24 PM
    BradyT88
    BradyT88 ┌∩┐(◣_◢)┌∩┐
    Somewhere Offroad
    Mostly Stock '05
    That was how I put 886's on my 5100's... Talk about scary!!
    I had to push the LCA down as far as I could get it to go to get the 5100's to fit. Was a pain but it worked.
  20. Apr 28, 2013 at 7:29 PM
    Raceline08
    Brett
    Santa Rosa, ca
    Ya it's a pain in the a$$! Did you run top plate spacers? I pushed the lcas down as far as I could and couldn't get the shock to match where it bolts too. Damn.
    Thanks,
    Brett
