886 OME lift with Dakars
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wolftaco0503, Apr 10, 2017.
  1. Apr 11, 2017 at 3:56 PM
    RutherML01
    RutherML01 Well-Known Member
    Micah
    Dickinson, Texas
    2007 Black DCSB
    You will have the 1/4" top plate spacer though. At least my 887 kit came with one.
    ChadsPride likes this.
  2. Apr 11, 2017 at 3:56 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    For the drivers side correct? Prevent Taco lean
  3. Apr 11, 2017 at 3:57 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Correct
  4. Apr 11, 2017 at 3:58 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Depends on how much lean you have.
    1/4" spacer is 1/2" lift. I had the OME trim packer on my 884s, which is 1/8" (1/4" lift) on the driver side. Then later added 1/4" top plate spacers to both sides.
    What you need for lean correction depends on what your amount of lean is. Mine didn't require 1/2" of correction.
    ChadsPride and RutherML01 like this.
  5. Apr 11, 2017 at 3:59 PM
    T4RFTMFW
    Also, you can run a 1/4" spacer on OEM shock bolts. Anything larger and you'll need extended bolts.
    ChadsPride and geekhouse23 like this.
  6. Apr 11, 2017 at 4:01 PM
    T4RFTMFW
    Pic for visual with a full Dakar pack and 265/75/16.
  7. Apr 11, 2017 at 4:07 PM
    PackCon
    Connor
    It's so pretty
  8. Apr 11, 2017 at 6:33 PM
    Wolftaco0503
    Wolftaco0503 [OP] Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    That is what I want my rig to look like Plus a Scoop
  9. Apr 11, 2017 at 8:16 PM
    RigginsTaco
    RigginsTaco Well-Known Member
    Andreas
    Boring taco with mods
    Stuff...
    887 are the 4runner spring right? I have the ome runner springs and I sit about 2.75" with a bumper and winch
  10. Apr 11, 2017 at 8:26 PM
    geekhouse23
    Correct. They are for the 4Runners
    RigginsTaco[QUOTED] likes this.
  11. Apr 20, 2017 at 12:09 PM
    PackCon
    Connor
    Question: If I wanted to do an OME 3'' lift w/ Dakars and Nitros in the rear but don't have all the funds now, could I do OME 886s in the front with what ever strut they come with (Bilstiens right?) and the .25" spacer for the driverside will I get a level? Then I can just do the dakars later?
    Or am I mad?
  12. Apr 20, 2017 at 12:56 PM
    geekhouse23
    What to get the funds. Unless you love the rear bro-lean squatted truck look
    Plus the 886's will rattle bones up front with zero weight. 886's with OME shocks ONLY.
    virvak2 likes this.
