888’s?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BLKYota, Aug 24, 2020.
  1. Aug 24, 2020 at 5:24 AM
    BLKYota
    BLKYota [OP] Active Member
    2016 Black Sport. 6spd man
    Hey folks,
    2016 TRD Sport dbl cab short bed
    I’m about to throw in some 5100s I picked up with OME 888 springs. Will these be too stiff? Should I put my stock ‘16 sport springs on there instead?
    also, with either spring set, I’d like to get 2.75” -3” of lift. What notch should the 5100s be set on? Will spring choice affect lifts at all or is it only based on shock setting?
  2. Aug 24, 2020 at 6:05 AM
    TurdTaco64
    TurdTaco64 Well-Known Member
    Brandon
    Fort Collins
    2019 Cement TRDOR 6MT
    I have the same setup, the springs won't make a huge difference in the ride. It's mostly in the valving of the shocks. That being said, 5100's are firmer than stock, at least in my OR, but I'm a good way. Can't say for sure with your sport, but I would guess they might actually be softer. Also, put them on the lowest notch and you'll get about the lift you're looking for. Just be warned, many 888's have been known to say, including mine. Have fun assembling the struts! It's a bitch.
    71tattooguy likes this.
  3. Aug 24, 2020 at 7:01 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Big debate on this topic. Oem springs meant to be paired with 5100’s Just my 2cents. Good luck
  4. Aug 24, 2020 at 7:10 AM
    Summers_Kytaco_19
    Summers_Kytaco_19 “I did that in 2wd” rdpoe
    Steven
    Independence, KY
    19 trd OR tacoma
    They won’t be to stiff I’m on 5100 and 888 springs. I really like the way it rides. And yes use the lowest setting on the shock. They’re really not that hard to put together. If you’re worried about it take the struts out and have a shop put the new ones together with your factory top hat. I do it for people all the time at my shop
