89 bed on 97 Tacoma
Discussion in 'General Tacoma Talk' started by 97 toyota tacoam, Sep 7, 2024.
  1. Sep 7, 2024 at 6:34 PM
    97 toyota tacoam
    97 toyota tacoam [OP] Member
    I was wondering if you can put 89 pickup bed on 97 Tacoma or if anyone has done it and how to
  2. Sep 8, 2024 at 8:14 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
  3. Sep 8, 2024 at 11:32 AM
    I-Give-Up
    I-Give-Up Well-Known Member
    West Phoenix, AZ
    2023 Ice Cap Tacoma TRD
    Meso spare fuse holder. Aluminum gas cap holder. Genuine Toyota bed lights. Bed molle racks. Ammo case storage under hood. In-bed spare tire. Automatic underhood lights. Gooey glurp on frame.
    If you have a shell to measure against, or can have someone do it for you, the tape measure and a 36 inch straight edge are your friends. I have done this with a Dodge PU, and a friend retrofitted a Chevy squarebody shell to his 1994 Dodge Ram long bed.
    • Measure the length of the tops of the frame rails of the truck.
    • Measure the length of the bottom edges of the sides of the shell. Are they adequately close to the length of the frame rails? (You can't make a 5 foot shell fit a 6 foot bed without modification.)
    • Measure the width of the top edge of the truck bed.
    • Measure the width of the tailgate as well as the width of the truck bed from frame rail to frame rail.
    • Measure the width of the bottom edge of the shell. Measure the width of the shell tailgate and the outer edges. Are they close to the analogous measurements from the truck?
    • Use a straight edge (a carpenter level works) determine if the truck rear window will interfere vertically into the bed area. Does the truck have a faux "spoiler" built into the roof, like the 2024 Tacomas do?
    • Similarly, determine if the shell is shaped so as to interfere with the rear window area of the truck.
    If all looks good, the shell will probably fit, even if it was designed for some other truck. You may need to modify the shell a little, especially in the front. In my case, I had to replace the bottom front 1 inch by 1 inch aluminum angle with 2 inch by 2 inch angle to slide the shell back and properly seal the front, and (most important) also clear the tailgate. You may also need to use a bar clamp to squeeze the back end of the shell to fit at the tailgate. In my Dodge experience, I had to install a stainless steel tailgate cap to prevent the cap's hatch rubber seal from rubbing the paint off.
    In my friend's case, retrofitting the Chevy to his 1994 Dodge, he squeezed the back of the shell closer each time he installed it. He just used a strong friend, being the cheap guy he is.
    YMMV.
    Knudsen likes this.
  4. Sep 8, 2024 at 1:24 PM
    soundman98
    NW Indiana
    he's not installing a shell.
    he's asking to take the truck bed off
    and install this truck bed instead
    which is going to take lots of steel/scrap steel for new mounts, multiple grinders, a welder, and a sawzall at a minimum.
    MadNachos likes this.
  5. Sep 8, 2024 at 2:10 PM
    I-Give-Up
    West Phoenix, AZ
    With apologies, this is one of the worst misreadings of a post I have ever made. :goingcrazy: Flame away. I deserve it. :crapstorm:
    MadNachos and soundman98[QUOTED] like this.
  6. Sep 8, 2024 at 2:18 PM
    soundman98
    NW Indiana
    all your measurement suggestions are still somewhat accurate for a starting procedure.
    this is still just as much work as making a chevy-anything fit a dodge-anything!
  7. Sep 8, 2024 at 2:20 PM
    EveryDayIsTacoTues
    EveryDayIsTacoTues Well-Known Member
    2012 Pyrite Mica DCLB TRD Sport
  8. Sep 8, 2024 at 2:59 PM
    Knudsen
    Knudsen Well-Known Member
    Jon
    2008 Access Door TuRD
    To bet installed: bling grill, headlights, fog lights.
    I was going to do that. But then, as usual, I-Give-Up :rofl:
    I-Give-Up[QUOTED] likes this.
  9. Sep 8, 2024 at 3:14 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    Hehe, it happens, Lord knows I have never done the same! But your intentions were good, can't fault that!
    soundman98 and I-Give-Up[QUOTED] like this.
  10. Sep 8, 2024 at 8:44 PM
    soundman98
    NW Indiana
    new threads don't finish projects!
    i love oddball stuff, and i'm all for helping anyone through figuring out oddball stuff, but the OP needs to show some effort--look into hijackzx1's multi-zone carpc/car audio build/ show vehicle build from back in 2010-ish.. he had tons of issues, but was extremely passionate about seeing it through, though i think project scope creep got to him eventually when it all outpaced his wallet... but i loved working with him on a lot of issues that no one else could explain, or were even trying at the time...
    this guy seems to keep looking for someone else to lay out all the pieces and build a simple conversion for him and has all but turned down every chance someone's offered constructive advice and just keeps making new threads asking for the same thing. the bad news is that the answers not changing. and with a lack of new answers, it means the OP needs to alter his own perspective and approach to the project.
