89 pickup hood on a 97 Tacoma
Discussion in 'General Tacoma Talk' started by 97 toyota tacoam, Aug 8, 2024.
  1. Aug 8, 2024 at 9:09 AM
    97 toyota tacoam
    97 toyota tacoam [OP] Member
    Does any one know if a 1989 Toyota pickup hood would fit a 97 Tacoma and does any one know if the rear bumper off the 89 will work in 97 and also does anyone know if the bench seats out of a 89 will work in a 97
    thank you
  2. Aug 8, 2024 at 9:11 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Probably not on the hood since they're 2 different body styles. The bumper and seat may take a little tweaking but it's possible.
  3. Aug 8, 2024 at 8:55 PM
    undisider
    undisider Member
    Nathaniel
    2x 99 tacos
    one "stock" TRD one lifted/locked, supercharged SR5
    I have both generations of truck non of it will be a bolt on fit. The bumper if stock (any wrap around is out the 1st gen bed is wider) could be modified the frame rails are the same width but the bolt spacing is different. The seat might fit width wise in the cab but the mounts are different. The hoods are very different shapes so no luck there.
