8AT Transmission Slip?
Discussion in '4th Gen. Tacomas (2024+)' started by tmac5809, Jul 8, 2024.
  1. Jul 8, 2024 at 9:42 AM
    tmac5809
    tmac5809 [OP] Well-Known Member
    I noticed the Tacoma in this video did a weird thing when shifting around 72mph at WOT. Has anyone with the 8AT experienced this?
    At 0:46 and again at 1:36
    2016Tacoman likes this.
  2. Jul 8, 2024 at 9:59 PM
    Digitalwiz5
    Digitalwiz5 Well-Known Member
  3. Jul 8, 2024 at 11:36 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Looks like torque management, not slip.
  4. Jul 9, 2024 at 3:27 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Problem with adding a aftermarket exhaust on a turbo engine . You lose back pressure .
  5. Jul 9, 2024 at 4:41 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    That doesn't mean anything.... The turbo itself creates back pressure for the engine. Having a free-flowing exhaust on a turbo motor creates no issues.
    Pwakchop, abou824 and crazysccrmd like this.
  6. Jul 9, 2024 at 6:36 AM
    tmac5809
    Our Honda Pilot does something very similar in the 4-5 shift with anything > 40% throttle.
  7. Jul 9, 2024 at 6:41 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    For sure... it only helps. The whole back pressure makes tq is nonsense.
    turkeyslayer66 likes this.
  8. Jul 9, 2024 at 7:04 AM
    Mallcrawler20
    Ehh wrong
    ridefreak likes this.
  9. Jul 9, 2024 at 7:06 AM
    fourfourone
    I think you need to do some reading on how a turbo works lol.
  10. Jul 9, 2024 at 7:10 AM
    tmac5809
    I'm no expert but I am pretty sure the turbocharger itself introduces some back pressure, but a free flowing exhaust is good for a turbo car.
    fourfourone likes this.
  11. Jul 9, 2024 at 7:13 AM
    abou824
    abou824 Well-Known Member
    Aidan
    Central PA
    '21 TRDOR Army Green 6MT, '13 Lexus RX350
    TRD Lift (Toyota 5100's) LT265/75 AT4W Method MR305 16x8 Bronze ARB Diff Breather Subaru Tweeters Garmin Dash Cam Clutch accumulator delete plate Vibration dampers on MT driveshaft shield
    It's not nonsense at all and is incredibly important for exhaust scavenging. On my other car, you lose a significant percentage of your horsepower by sizing up the exhaust diameter. For turbo engines however, the bigger the better.
  12. Jul 9, 2024 at 7:19 AM
    RX1cobra
    19 OR
    https://www.youtube.com/watch?v=_PVXvHkr-Vs
  13. Jul 9, 2024 at 7:20 AM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    Do clarify then. With every turbo'd car I played with in the past reduced restriction post turbo was always key aswell as isolating a smoothing out exhaust gas before entering was always key.
    This sounds alot like n/a mentality where balancing back pressure to limit scavenging/valve float is the goal
  14. Jul 9, 2024 at 7:22 AM
    abou824
    Aidan
    Central PA
    From personal experience, dyno before and dyno after, 20hp was lost by using an 80mm diameter exhaust vs a 60mm. Supercharged 4cyl. Helps the engine flow way more air as it increases exhaust velocity.
    RX1cobra[QUOTED] likes this.
  15. Jul 9, 2024 at 7:26 AM
    Mallcrawler20
    Turbo backpressure is the pressure that builds up in the exhaust system due to the turbine wheel’s operation.
  16. Jul 9, 2024 at 7:30 AM
    RX1cobra
    19 OR
    That's the fun thing about cars... you can make general statements but there is always an exception. For the most part a larger, freer flowing exhaust will make more power. There many things that play into scavenging of exhaust and its not just the pipe size. They showed pretty well in that video, great series if you've never watched it, that the smaller pipe did nothing to help low end power and only killed it on the top.
  17. Jul 9, 2024 at 7:49 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    Turbo Aside, adding a freeer flowing exh def makes more power up high closer to WOT and the expense of low end HP, it just shifts the engine's power curver higher. Nothing is free. Large diameter exhausts can reduce velocity which is less efficient at low RPMs = less power in those ranges. Factory sizing of the exh is a compromise between the two since few run at WOT and mostly at lower RPMs. Since many equate torque with low end power it's often referred to that way but that's incorrect, peak torque is likely higher with a larger exh but it doesn't help anything on the low end and often makes it worse.
  18. Jul 9, 2024 at 7:52 AM
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
  19. Jul 9, 2024 at 7:54 AM
    turkeyslayer66
    turkeyslayer66 Well-Known Member
    mike
    22 AG Trd Sport
    Exhaust "back pressure" is nonsense. What you want is exhaust scavenging. This is achieved through primary pipe diameter and length, along with collector diameter and length. Too large or small of these diameters and lengths can reduce scavenging, reducing power output at the rpm range desired. A turbo is driven by rapidly expanding exhaust gas, not back pressure, and exhaust design will be different. There are a ton of resources available to use to get a good understanding of how all this applies to horsepower and torque production in a 4 stroke engine. Turbocharged engines go way back, it's not a new technology.
    Newwt likes this.
  20. Jul 9, 2024 at 8:05 AM
    Vitamins
    Vitamins Well-Known Member
    2024 TRD OR
    No dog in this fight, but in that video, that is a *heavily* modified carbureted engine, and the video is sponsored by a tuning shop.
    "Result may vary."
    Mudc4t likes this.
