8ohm subs alright?
Discussion in 'Audio & Video' started by TuFerLife, Jul 20, 2012.
  1. Jul 20, 2012 at 5:37 PM
    TuFerLife
    TuFerLife [OP] 2 4 LIFE!!!
    Taylor
    Chattanooga, TN
    2011 Ford Raptor (I'm a traitor)
    Hey guys,
    Ordered a couple of jl audio 10w1v2's for my truck and the company called and said "were out of the 4ohm version, is the 8ohm alright?" I said I didn't know, but told them I was running a jl audio 500/1v2 amp and they said 8 ohms were fine. Do I need to hold out for the 4ohms, or will the 8ohms be alright?
    Excuse my ignorance...
  2. Jul 20, 2012 at 5:59 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    The 4ohm speakers will be way more efficient, taking less power than the 8ohm speakers.
  3. Jul 20, 2012 at 6:04 PM
    TuFerLife
    Taylor
    Chattanooga, TN
    Can you explain efficient? The guy said that normally he wouldn't run 8ohm, but this jl audio amp runs constant power so I can just parallel the subs to 4ohm and I'll be fine... Or something like that
  4. Jul 20, 2012 at 6:09 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    It depends on how much power you want to run from the amp. By "a couple" I'm going to assume 2, at this point with the 8 ohm version you can wire them to run at 4 ohms or at 16 ohms. With the 4 ohm version you can wire to a 2 ohm or an 8 ohm final load. Personally, I'd hold out for the 4 ohm version's so that you can run the full 500rms of that amp at a 2 ohm final load rather than 300rms that the 4 ohm final load of the dual 8 ohm subs will deliver.
    Edit: I'm not sure what he means by efficient but the higher the ohm load the less the power will be. A 1 ohm load will run higher power easier whereas a 4 ohm load will run power a little harder.
  5. Jul 20, 2012 at 6:16 PM
    TuFerLife
    Taylor
    Chattanooga, TN
    That's why you're "that guy"!!! Thank ya sir
  6. Jul 20, 2012 at 6:23 PM
    Warhorseforever
    Will
    Sand Lapper
    We were all noobz at once, hell I'm just now getting into building my own ported boxes and I've been installing for friends for a few years. Good luck.
  7. Jul 20, 2012 at 6:27 PM
    t4daddy
    North Alabama
    Exactly more efficient, better use of the amps power.
  8. Jul 20, 2012 at 6:29 PM
    t4daddy
    North Alabama
    I, also would hold out for the 4ohm models, or shop elsewhere.
  9. Jul 20, 2012 at 6:45 PM
    TuFerLife
    Taylor
    Chattanooga, TN
    Update... They said the 4ohms were backordered through JL so I said I didnt want the 8ohms. So now I'm back to square one. Looking for different sub now. I liked those because I found them for $110 a piece, haha.
    I would love to hear suggestions of another sub you might suggest... Note I'm only working with 5" mounting depth...
  10. Jul 20, 2012 at 7:18 PM
    t4daddy
    North Alabama
    Shop around, some other shop may have them in stock if that's what you want.
  11. Jul 20, 2012 at 7:20 PM
    TuFerLife
    Taylor
    Chattanooga, TN
    I don't have to have those... I don't know much around them. I had w7's and I loved them so much I just fell in love with jl audio. But I'll search some posts on here, do a little bit of googling, and see what I can find out... Thanks again gentleman
  12. Jul 20, 2012 at 7:28 PM
    t4daddy
    North Alabama
    sonicelectronics.com
  13. Jul 21, 2012 at 12:57 AM
    Warhorseforever
    Will
    Sand Lapper
    If you've got the money the JL TW5 is an excellent sub. Also you can fit W3's in the back of a 2nd gen DC.
  14. Jul 21, 2012 at 7:51 AM
    TuFerLife
    Taylor
    Chattanooga, TN
    I was looking and the top mount depth is 5.93" so that scares me...
    Here is a link to my box... http://www.halfpricecaraudio.com/To...l-10-Subwoofer-Enclosure-Sealed-Box-Black.htm
    I was looking at the JL 10w1's (http://www.woofersetc.com/p-2731-10w1v2-jl-audio-10-subwoofer.aspx) but I talked to crutchfield and he is recommending the rockford fosgate's... He said he likes JL but he thinks they are made more for ported boxes, so he recommended these rockford fosgate's for a sealed box (http://www.crutchfield.com/p_575R2SD410/Rockford-Fosgate-R2SD4-10.html?tp=111)
    I also found some kenwood's that look like they've gotten pretty good reviews (http://www.sonicelectronix.com/item_9849_Kenwood-eXcelon-KFC-XW1000F.html)...
    Thoughts?
  15. Jul 21, 2012 at 9:40 AM
    TuFerLife
    Taylor
    Chattanooga, TN
  16. Jul 21, 2012 at 10:51 AM
    sfcadams
    sfcadams Retired Senior NCO
    Dan
    Elizabeth, Indiana
    2011 TRD Off Road DCSB Prerunner Skeewped
  17. Jul 21, 2012 at 11:07 AM
    TuFerLife
    Taylor
    Chattanooga, TN
    btw... they were 4ohm subs... I'll get y'all a review once I see the subs next week
  18. Jul 21, 2012 at 11:46 PM
    Warhorseforever
    Will
    Sand Lapper
    A friend of mine has those kenwood's and I really like them. He has them in a generic pre-fab ported box "tuned to 30Hz" so they don't sound as good as they could but still rock along nicely.
  19. Jul 23, 2012 at 12:09 PM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    If it hasent been said, the higher the ohm load the less thd you get, but it dosent really matter with subwoofers
  20. Jul 23, 2012 at 12:34 PM
    TuFerLife
    Taylor
    Chattanooga, TN
    BTW, I think I made a mistake ordering from onlinecarstereo.com... All their reviews online are GARBAGE!!!! I've been calling them all day seeing when my stuff will ship out... If it doesn't ship out by EOD, I guess I'll be cancelling and going back to square 1...
    I'll keep y'all in the loop...
