.:-- 8th Annual KY/TN March 2020 Land Between the Lakes Meet--:.
Discussion in 'Tennessee' started by allmotorrex, Dec 5, 2019.
  1. Jan 9, 2020 at 8:57 AM
    #121
    imjustabill1970
    imjustabill1970 Twitter: imjustabill1970
    bill
    clarksville, tn
    2017 TRD Off Road DCSB
    SUSPENSION: Icon Stage 4 with tubular UCAs WHEELS: Black ProComp 69 TIRES: BFG KO2s at 265/75/16 Partially debadged Diaz Fabrication Model T up front
    Advice - I currently have those stock predator steps on my truck with an Icon Stage 4 that gave me about 2" overall. Tires are 265/75/16s...should I remove the predator steps?
    Thanks.
  2. Jan 9, 2020 at 9:28 AM
    #122
    Breezy
    Breezy vaping in my subaru
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    Unless you have sliders I would leave them on. Better than nothing.
    Or you could also argue they will hang on things more and be a damage multiplier if bent upwards
    :notsure:
  3. Jan 9, 2020 at 9:51 AM
    #123
    imjustabill1970
    bill
    clarksville, tn
    I know...wish I could just take the hanging steps off.
  4. Jan 9, 2020 at 10:11 AM
    #124
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    ATM6969420 series
    Most of us bring enough power tools that if they need to be removed they could be taken off in a timely manner.
    Breezy, Mr.Bl0nde and imjustabill1970 like this.
  5. Jan 9, 2020 at 10:32 AM
    #125
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    you could. Just cut them off, sand, and repaint. But for that much work just order sliders
  6. Jan 9, 2020 at 11:54 AM
    #126
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    None of my coolers fit in trunk of the FRS. Will need to buy a new cooler I guess.
    EZ Up won't fit either.
    LOL
  7. Jan 9, 2020 at 11:58 AM
    #127
    Ibocnet
    Ibocnet Well-Known Member
    Rich
    2010 TRD Sport DCLB
    Toytec 3" front lift, OME 3" rear lift, ARE MX Cap, Budbuilt Armor
    Bud Built in NC has sliders in stock
  8. Jan 9, 2020 at 12:21 PM
    #128
    Justinogo
    Justinogo Well-Known Member
    Justin
    Memphis, TN, USA
    1985 4Runner
    3rz, 37s, Locked, 5.29s, 4.7 Marlin case, OG LongFields
    Get a big chassis mount wing. Strap EZ-up onto it
  9. Jan 9, 2020 at 12:48 PM
    #129
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    Take em off, they're aluminum and will end up royally screwed up by small stuff, plus they eat a lot of clearance.
  10. Jan 9, 2020 at 3:30 PM
    #130
    Robertocritser
    Levi
    KY
    08 sport
    ATM6969420 series
    Dont miss that lol
  11. Jan 10, 2020 at 5:57 AM
    #131
    allmotorrex
    allmotorrex [OP] Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    You should def do that. You can practice your drifts with me and Levi.
  12. Jan 10, 2020 at 8:28 PM
    #132
    Robertocritser
    Levi
    KY
    08 sport
    ATM6969420 series
    Yes the drifts!!!
    imjustabill1970 likes this.
  13. Jan 11, 2020 at 5:55 AM
    #133
    imjustabill1970
    bill
    clarksville, tn
    Hey man...Stewart County had some significant wind damage this morning from this storm passing over. Be careful if you're still headed that way!
  14. Jan 11, 2020 at 6:17 AM
    #134
    TN_TacoSupreme
    TN_TacoSupreme The Yota Peddler
    Allen
    Springfield, TN
    2014 Silver Tacoma TRD Sport
    As much as I can til' my wife blocks my Amazon account...
    Thanks buddy...we canceled our trip today. Rain is one thing but crazy storms I’ll pass. Thanks again for the heads up!
  15. Jan 11, 2020 at 6:51 AM
    #135
    imjustabill1970
    bill
    clarksville, tn
    No problem.
  16. Jan 11, 2020 at 6:25 PM
    #136
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    I mean, I dont want to be the ONLY reason you bring the truck...but I do enjoy that thing.
  17. Jan 20, 2020 at 5:12 PM
    #137
    Skootter14
    Jeremy
    Sadly I have my coilovers boxed up heading to Fox for a rebuild (I'd rather be doing this myself). I've had a slight issue with them for a while now, drastic driver side lean. Upgraded springs to 650# (or so I thought; spring test will tell the truth) then added a winch so maybe 700# springs are needed. A tech at fox mentioned there may be an issue with the shock itself along with a weak spring; they'd be able to ID anything upon tear down.
    Also sent off my BORA wheel spacer to get a lug pressed in since a shop broke it off when I had them rotate my tires a few months back (ive been using them since 2014 and I have had no issues taking lugs on and off. . .let a shop do it once and thats what I get). They have a lifetime warranty so I figure let them do the work.
    Getting ready for the trip coming up, cant wait!
    KRAMERICA likes this.
  18. Jan 20, 2020 at 5:57 PM
    #138
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Is that a different bumper on the front? Looks beefy as fuck!
  19. Jan 20, 2020 at 7:34 PM
    #139
    Skootter14
    Jeremy
    it is. A friend and I made that with his tube bender in his garage when I was in WA. took us 36 hours of work; I think 2 full weekends. we designed the bumper completely around the winch (and we made the winch mount also, but they are separate so you can remove the bumper and not the winch if need be). I didnt write anything down for design, just had an image in my head and created it. very happy with the result.
  20. Jan 21, 2020 at 3:42 AM
    #140
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    Don't do 700lb springs. You'll get far better performance from 650s.
