9 or 10 inch wide wheels?
Discussion in 'Wheels & Tires' started by Natenite, Oct 12, 2019.
  1. Oct 13, 2019 at 2:22 PM
    Natenite
    Natenite [OP] Well-Known Member
    Springfield Mo
    2003 Tacoma 4d TRD Radiant Red
    Ok. Wow. I was so waaay off. Thank you for the info. So if I put the 8 with 0 offset would the inner wall of the tire move any or would it stay effectively in the same spot?
  2. Oct 13, 2019 at 2:26 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    It will effectively stay in the same place so no uca rubbing issues but since it’s 1.5” wider than your current wheel the outer edge will be 3/4” further out.
    Natenite[QUOTED][OP] likes this.
  3. Oct 13, 2019 at 2:26 PM
    gotoman1969
    Good luck and I hope the info helped.
    Natenite[OP] likes this.
  4. Oct 13, 2019 at 2:32 PM
    gotoman1969
    Maybe the discount tire guys have a 16x8 0 offset wheel there you can set on your truck, you’ll see there will be a nice difference compared to the stock wheel.
  5. Oct 13, 2019 at 2:57 PM
    Natenite
    Springfield Mo
    Planning to go by Monday and ask them some things. The wheel I am currently looking at on the website says it has an off set of 1. Not plus one or negative one, just one. I’ll have to figure out how that affects things.
  6. Oct 13, 2019 at 3:49 PM
    gotoman1969
    If it’s just says 1 then it will positive 1, anytime it’s negative it will have a minus sign in front of the number. Positive 1mm is basically 0
