9" Suspension Lift, Off-road capabilities
Discussion in 'Suspension' started by kbrebel04, May 12, 2012.
  1. May 12, 2012 at 1:33 PM
    kbrebel04
    kbrebel04 [OP] Well-Known Member
    Kyle
    Virginia Beach
    12 4x4 TRD Sport
    Hello everyone,
    I was wondering, would putting 9" of suspension lift on a Tacoma negatively effect its off-road performance? If so, how?
  2. May 12, 2012 at 1:35 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Yes. You'd destroy your driveline and eat CV boots like popcorn.
    And look like a colossal douche with the giantest penis ever.
  3. May 12, 2012 at 1:35 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2005 Prerunner TRD Off Road
    265/75/16 BFG A/T, 18" Magnaflow, K&N Intake Filter, Ultra-Gauge, Kobalt Toolbox, Metal Tail Light Guards, Cobra 19 and 4ft fiberglass antenna, Plasti dipped Badges/lower valance/rear bumper/grill/bullbar/ac controls, black DIN kit, JVC KD-X40, Wet Suit Seat Covers
    Unless you SAS and go with wider axles, I'd say 9" of lift plus whatever lift you get from the larger tires would make the truck way too top heavy.
  4. May 12, 2012 at 1:38 PM
    kbrebel04
    Kyle
    Virginia Beach
    12 4x4 TRD Sport
    Thanks guys, What would be the most optimal lift for a off-road tacoma be then?
  5. May 12, 2012 at 1:40 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Morty
    Outer Space
    OME or toytecs
    Or you can spend a couple grand and get some CO's, UCA's, spring kit, and rear shocks.
  6. May 12, 2012 at 1:41 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    3". Cab mount chop and stuff 35". Looks mean.
  7. May 12, 2012 at 1:41 PM
    kbrebel04
    Kyle
    Virginia Beach
    12 4x4 TRD Sport
    5000-6000 Parts, all the work I can do myself
    Thats for lift, tires, wheels
    I already have money aside for lockers and labor
  8. May 12, 2012 at 1:41 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    3" lift is the most you'll need
  9. May 12, 2012 at 1:42 PM
    04LTtacoma
    Morty
    Outer Space
  10. May 12, 2012 at 1:43 PM
    04LTtacoma
    Morty
    Outer Space
    or 4", LT will give you 4" of lift.
  11. May 12, 2012 at 1:45 PM
    Sunner
    Sunner Well-Known Member
    Yeah 4K should get you started very well on a MT setup. Thats about what Im looking at right now on mine.
  12. May 12, 2012 at 1:46 PM
    kbrebel04
    Kyle
    Virginia Beach
    12 4x4 TRD Sport
    Awesome responses guys, noob question incomming.
    "Mid Travel"?
  13. May 12, 2012 at 1:48 PM
    04LTtacoma
    Morty
    Outer Space
    Mid-travel is only going to give you 8" max, I think.
    ^^^ I could be wrong.
    Long Travel is going to give you about 14" of travel.
    EDIT:Anyone correct me if I am wrong.
  14. May 12, 2012 at 1:48 PM
    Sunner
    Its between stock and Long Travel, so hence the term. Its a gray area of what is considered MT but to me its extended travel shocks, upper control arms, leaf pack. Then you can add from there, bumps, straps etc.... Gets the job done and isnt too bad on the wallet.
  15. May 12, 2012 at 1:50 PM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series LC
    Tons and 40s
    Basically new UCAs and extended travel coil overs. What size tire do you want to run? I'm running 35s on 3" lift and cut 2" out of flares and fenders. Aint easy to do though. You can stuff 35s with an AP LT kit and minimal cutting, at least not cutting into sheet metal.
    9" is too high, you want a lower center of gravity, plus with a DB kit you can't run solid skids. With 3" you can get a full set of beefy skids to protect everything under the truck.
    Just my .02
  16. May 12, 2012 at 1:50 PM
    Sunner
    Heres my planned set up that Ill be throwing on in the next few weeks to give you an Idea
    Camburg UCAs w/ Icon Remote Resis up front
    All Pro expedition pack w/ Icon Remote Resi in the rear
    Wheelers bump stops up front
    Timbren Bumps w/ All pro U bolt flip kit in the rear
    Extended brake lines from Toytec
    BFG AT KOs 285
    AP 2" Fender Flares
    SpiderTrax 1.25" Spacers all around
    Reinforcing Motor mounts
    Custom prerunner bumper
  17. May 12, 2012 at 1:51 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    Denver/Phoenix
    11' Tacoma & 84' Yota
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Toyo R/Ts, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tints, 2 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, JBA Long Tubes, URD o2 sims, Trail Gear bumper/Sliders, Crown brake lines F/R
    Do you want to run a set of skids?
    with a 6" lift theres not much protection for the front diff/db
    Edit: Max beat me to it
  18. May 12, 2012 at 1:51 PM
    kbrebel04
    Kyle
    Virginia Beach
    12 4x4 TRD Sport
    Nice, I will be using it for recreational. It is my daily driver, 5-12 times a year I would like to hit trails with it, nothing crazy but novice climbing, off-road camping etc.. Not all sure what I would need with that.
    I have a TRD Sport, so no lockers. Suspension, wheels, tires, rear(and front?) lockers and w/e else I need to look at. Just not sure what exactly
  19. May 12, 2012 at 1:52 PM
    Sunner
    :cheers:
  20. May 12, 2012 at 1:52 PM
    04LTtacoma
    Morty
    Outer Space
    Why are you going with the SpiderTrax 1.25" spacers all around?
