90,000 mile maintenance
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hook78, Jul 9, 2023.
  1. Jul 9, 2023 at 8:50 AM
    Hook78
    Hook78 [OP] Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Sitting at 88k, starting to do my planning for 90k.
    So far here’s what’s on my list:
    -front and rear diff oil
    -transfer case oil
    -engine oil, filter
    -intake filter and cabin air filter
    -spark plugs
    -drain and fill transmission
    -grease driveshaft
    A couple things I’m considering but unsure of based on higher difficulty, so may need to consider outsourcing:
    -power steering fluid
    -coolant
    -brake fluid
    None of the above have been done since acquiring the truck at 34k.
    Inputs on those, as well as any other maintenance or items to inspect, would appreciate it. Cleaning the MAF sensor and replacing the PCV valve are a couple other items that occurred to me as possibles…
    Truck does infrequent light off-roading and pulls a boat locally. Runs great. Want to keep it that way.
    ColoradoTJ likes this.
  2. Jul 9, 2023 at 9:04 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Yes to brake fluid and coolant
    Check drum brake shoe adjustment. Maybe pull the console and snug up the parking brake cable if needed
    Check torque at u-bolts and driveline flanges
    Don't worry about the pcv valve, they rarely fail these days
    Hook78[OP] and MarX like this.
  3. Jul 9, 2023 at 9:11 AM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    Inspect brake pads. Rotate tires. Serpentine belt is coming up soon. Consider that.
    Hook78[OP] likes this.
  4. Jul 9, 2023 at 9:14 AM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    I do power steering every 30-40K in my vehicles...well, the ones that don't have electric steering.
    Turkey baster works great for removing fluid. Do this 3-4 times with cycling the steering wheel from lock to lock with front tires off the ground.
  5. Jul 9, 2023 at 9:43 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I flushed all fluids at 90k and will flush every 60k going forward. I change gear oil every 30k.
  6. Jul 9, 2023 at 10:08 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Appreciate the comments so far.
    Adding brake inspection on all four corners, ubolt torque check, driveline flange bolt torque check, and will research the serpentine.
    Power steering sounds doable myself, maybe coolant is too. Brake fluid I just won’t do, maybe that’s the only thing I’ll need a shop to do.
  7. Jul 9, 2023 at 12:33 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
