90,000mi Maintenance
Discussion in '1st Gen. Tacomas (1995-2004)' started by KaBar, Oct 6, 2010.
  1. Oct 6, 2010 at 12:11 AM
    KaBar
    KaBar [OP] Well-Known Member
    East Coast
    04 TRD SR5 4x4
    ARB bullbar, Total Chaos UCA, OME 881, Wheeler 5 leaf, Bilstein 5100s, custom TRD skidplate, All Pro rocksliders w/ fill plate, Tundra brake upgrade.
    Just hit 90,000mi the other week and I want to make sure I take care of all the routine maintenance that is necessary.
    I'm going to change;
    -fuel filter, any particular brand?
    -front/rear differential fluid. Is Mobil 1 syn 75w-90 for both safe? additive?
    -transfer case fluid. Mobil 1 syn 75w-90.
    -Spark plugs. I suppose the dealer is the best place to get these.
    -Timing belt. Should I get the water pump changed as well?
    -O2 sensors. How difficult will that be?
    Is there anything that you would add? I have a 2004 3.4 V6 TRD with locking rear differential.
  2. Oct 6, 2010 at 12:50 AM
    TacomaDan
    TacomaDan Don't go off ninjin
    Daniel
    Woodland, CA
    1996 Toyota Tacoma Fully Not Loaded
    Love, Cobra 29 LTD BT CB w/ A2000 Highgear antenna, FOX/Fabtech Coilovers, Magnaflow
    Definitely replace the water pump as well as the timing belt tensioner when you do the timing belt. Try to replace as many replaceable things while the front of the engine is torn apart. There is also an idler pulley for the timing belt that is def recommended to change. Dont replace O2 sensors unless needed. The are good to go as long as they dont throw a code. Spark plugs. Def get the dual ground spark plugs that are OE or equivilant. You do not need to go to the dealer for those.
    http://www.autozone.com/autozone/pa...gg6Z8gctd?counter=6&itemIdentifier=945407_0_0_
    I dont know about a fuel filter but just get the OE replacement. It works just fine the way it is. And that should be just about it. I dont know about the fluid additives for the rear diff tho. I dont have a locker so maybe someone with one can chime in? Hope this helps
  3. Oct 6, 2010 at 10:55 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    My 2001 at 90,000 miles also got a new water pump when the timing belt was replaced... as a drip was seen (it never failed)... In fact, nothing ever failed on my '01... kept me in Toyotas, on #3 Tacoma now (5 year leases).
  4. Oct 6, 2010 at 11:18 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    -front/rear differential fluid. Is Mobil 1 syn 75w-90 for both safe? additive? No additive needed for the 01 I just changed mine with 80w-90w as it's recommended in the manual I have been reading that guys are using 75w-90w but it's all been 2nd gens
    -Spark plugs. I suppose the dealer is the best place to get these. You can get spark plugs just about any auto parts store
    -Timing belt. Should I get the water pump changed as well? Hell yes buy a timing belt kit that comes with everything you need to change.
    -O2 sensors. How difficult will that be? Just and opened end wrench and maybe some penetrating lube but Ive never changed mine so I could me wrong
  5. Oct 6, 2010 at 8:52 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    If ur changing the timing belt and water pump...u might as well do the T-stat while ur at it...all 3 are in the same basic location...
