90-100k DIY maintinence
Discussion in '1st Gen. Tacomas (1995-2004)' started by xSpyderguyx, Jun 14, 2010.
  1. Jun 14, 2010 at 4:37 PM
    xSpyderguyx
    xSpyderguyx [OP] Well-Known Member
    Caleb
    Washinton State
    2001 3.4L v6 SR5
    s40 Flowmaster 33" Toyo M/T tires 16" P.A wheels 3" revteck Suspension lift
    Hey TW:
    I had some questions about maintinence. So I need a 90k service and I havent got a quote yet but I want them to do the Timing Belt, Waterpump, Tranny flush and what not.
    But I want to do some of the cheaper, easier things. What are some of the things I can do to help my Tacoma live strong!
  2. Jun 14, 2010 at 4:38 PM
    RPain
    RPain Well-Known Member
    Chandler, Arizona
    2016 Tacoma DCSB 4x4 TRD Sport
    Link to build in sig
    i just hit 90k too, subd
  3. Jun 14, 2010 at 4:52 PM
    xSpyderguyx
    Caleb
    Washinton State
    2001 3.4L v6 SR5
    Did you have any work done?
  4. Jun 14, 2010 at 5:37 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The items I added above (in bold) are things that will be apart at the same time - have it all done at once.
    Other things? Front diff, rear diff, transfer case oil changes. Fuel filter change. Spark plugs changed, Lubricate drive shafts.
  5. Jun 14, 2010 at 6:57 PM
    RPain
    Chandler, Arizona
    not yet but i'd like to know what i should have done.
  6. Jun 14, 2010 at 9:47 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    It really comes down to how often you change/check other things. You do have some of this on your list already, but this is stuff that really should be checked out once in a while. Granted that some people may do more/less, this is a start.
    This is my basic maintenance list (I do it by month since its easier for me to schedule and I dont drive enough to go over the mileage):
    3 Month Check
    Check Tire pressure
    Check Brakes
    Check CV Boots/Ball Joints
    Check AF
    Check ATF
    Check PS
    Check Washer
    Check Belts/Hoses
    3 Month Maintenance
    Change Oil/Filter
    Grease Driveshaft zerks
    Rotate Tires
    Clean Air Filter (K&N reusable)
    24 Month Maintenance
    Replace Spark Plugs/check wires
    Clean Throttle Body
    Replace AntiFreeze
    Replace Diff Oil
    Replace ATF
    Replace Power Steering Fluid
    6 Year Maintenance
    Replace Timing Belt/Water pump/belts/hoses
    (if someone has suggestions to add to my list, please dont hesitate to share)
  7. Jun 15, 2010 at 6:56 AM
    Janster
    Jandy
    Lancaster, PA
    Aside from what we've already told you....
    Do you have an owners manual? It'll tell you everything in there....
