90 second oil change?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by QChawks, Feb 18, 2016.
  1. Feb 18, 2016 at 2:19 PM
    QChawks
    QChawks [OP] Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    thought this was a cool idea, I'm pissed I didn't think of it :frusty:
  2. Feb 18, 2016 at 5:12 PM
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    That's pretty cool.
  3. Feb 18, 2016 at 5:28 PM
    Turdsport
    Turdsport Well-Known Member
    Josh
    '14 TRD Sport Supercharged
    That's gonna be expensive. For the consumer anyway.
    tacoparadise likes this.
  4. Feb 18, 2016 at 5:38 PM
    SJC3081
    SJC3081 Well-Known Member
    Wappinger NY
    2011 DCLB 4x4
    Screw that I need my waste oil to burn out tree stumps.
    tacoparadise and AustinPizzini like this.
  5. Feb 18, 2016 at 6:18 PM
    Pigpen
    Dan
    Northwest Montana
    I use mine as bar lubricant for my chainsaws :D
  6. Feb 18, 2016 at 6:27 PM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Meh i bet itll be expensive compared to the 25 bucks i pay for oil and filter (buying the oil on sale/with rebates).
    Its an interesting idea but meh im not sold on it. Oil changes are already quick and easy. Doing a "5k service" only takes my 10-15 minutes as it is. The oil portion might be 3 or 4 minutes of that so not like im really saving much time.
  7. Feb 19, 2016 at 4:58 AM
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    The only thing I dislike about the 1GR-FE oil change is that the dipstick is useless until you run the engine for a minute. There's oil all over that thing if I check it while I'm filling.
  8. Feb 19, 2016 at 5:18 AM
    LEBM
    LEBM Thread Killer
    Eleanor, WV
    2021 TRD PRO 6MT Midnight Black
    Glad I'm not the only one with this problem. I've given up.
  9. Feb 19, 2016 at 5:23 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    It is just an external dry sump oil pan with quick connects. Not exactly earth shattering technology.
    Howard
