$90 wheel bearing replacement!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by slodc4, Sep 16, 2014.
  1. Sep 17, 2014 at 11:36 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    You say you spent $66 on the new bearing and $20 in pressing fees....
    Did you know in most cases where the bearing goes bad it takes the hub out with it?
    Inner seal costs?
    Outer seal costs?
    O-ring costs?
    It's cool to do something on the cheap, but not when you skip the most important stuff that keeps you from needing a new bearing in another 3,000 miles.
    I would never try and save $100 by re-using the hub and seals, but maybe that's just me :notsure:
  2. Sep 18, 2014 at 8:42 AM
    BamaToy1997
    Bill
    Navarre, FL
    I am always happy to answer a question. I recommend the 20 ton press. I had a 12 ton press and the arbor bent when trying to disassemble an old, seized up Tacoma wheel bearing assembly. So yeah, 20 ton is best. This one I have assembles over 1000 units without a problem, and disassembled over 100.
    Check my thread in my sig. I offer 12month/12k mile on all of my assemblies from any and all defects. This warranty is from me personally, as the parts that I buy are factory direct, so they have no warranty with them. But I guarantee everything.
  3. Sep 18, 2014 at 8:56 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    If you're gonna be a bear, be a grizzly.
  4. Sep 18, 2014 at 9:05 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    That's pretty damn impressive, congrats on that.
  5. Sep 18, 2014 at 11:50 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
  6. Sep 18, 2014 at 1:04 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
  7. Sep 18, 2014 at 1:08 PM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    I had one go out at 70K miles.....Spidertraxx spacers probably helped kill it.
  8. Sep 18, 2014 at 1:39 PM
    jdm94
    jdm94 Well-Known Member
    Ga
    14 DCSB Trd Sport 4x4 & 06 DCSB Trd Sport
    $100 if you have the 4x4 model truck because if your truck is 4x2 will $200!
  9. Sep 18, 2014 at 2:27 PM
    jdm94
    Ga
    Are the bearings for the 4x4 and 4x2 truck the same?
  10. Sep 18, 2014 at 6:18 PM
    vram74
    vram74 Well-Known Member
    05 Prerunner SR5
    "Why 4x2 cost more than 4x4?" -CAaaptain CAaaaveMAaannn!!!
    "4x2 = 8 and 4x4 = 16, therefore logic dictates 4x4 should cost more" -Spock
  11. Sep 18, 2014 at 6:54 PM
    jdm94
    Ga
    What??
  12. Sep 18, 2014 at 7:00 PM
    vram74
    05 Prerunner SR5
    LOL! You must be too young to get the humor :p
    I was just asking why the 4x2's cost more, that's all.
  13. Sep 19, 2014 at 1:14 PM
    BamaToy1997
    Bill
    Navarre, FL
    The 4X2 hubs can be bought all day at your dealer for $160, not $200. Bit of a difference.
    The bearings themselves are the same. It is the hub that gets pressed into the bearing that is different.
  14. Sep 20, 2014 at 6:09 PM
    jdm94
    Ga
    Thanks!!!
    Bought the harbor freight press, I'm gonna order the bearing later today so I hope get the job done next weekend.
  15. Sep 20, 2014 at 6:12 PM
    #35
    jdm94
    Ga
    When i said $200 I was talking about the difference between the assemblies 4x4 and 4x2. If you get the job done like the guy did you will save $100 if you have 4x4 truck and $200 if you have the model 4x2.
  16. Sep 21, 2014 at 11:20 AM
    #36
    BamaToy1997
    Bill
    Navarre, FL
    The problem though is if the hub itself is reusable. That is what comes up that people have not noticed. The area of the hub where the seal on the bearing rides has a tendency to get damaged when the bearing goes bad in the first place. If the hub is not perfectly flat, and no grooves, then you are fine. What happens though is that a bad bearing allows the seal to press in the wrong area, or even have the seal damaged where it rubs a groove on the edge of the hub. If you put these hubs back in, then many times the grooved hub will damage the seal, and you are back where you started: A bearing that gets destroyed.
  17. Sep 21, 2014 at 11:29 AM
    #37
    Canufixit
    New England
    Bama toy 1997, I've not replace a Tacoma Front bearing - So I thought I'd ask - Are not the bearings Sealed?? IF so, why the extra seal??
    Thanks!
  18. Sep 22, 2014 at 10:34 AM
    #38
    BamaToy1997
    Bill
    Navarre, FL
    Depending on the brand of bearing, the better ones have a dust seal on the bearing itself, but it is not designed for heavy dirt, crud, water, etc. There is a seal in between the bearing and the hub to keep out this stuff, and then for the 4WD units, there is a seal between the CV axle and the steering spindle, which is the back side area of the bearing. All of these work together the best they can to keep out water, dirt, and mud.
  19. Oct 7, 2014 at 8:33 AM
    #39
    gfiber
    gfiber Well-Known Member
    Gary
    Seattle, WA
    2017 Black TRD Sport Access Cab
    TRD sport pkg, Towing Pkg, Ham radio installation, bed lights, front 32 inch LED Bar behind the grill.
    About bearings coming off with a bang when pressed. I once had a friend who worked at an auto parts machine shop. He wrapped any bearing he could with an old leather jacket before pressing to contain anything that may go flying off under pressure. Maybe using something like a bell housing blanket drag racers use would work too. I received and installed 2 new front bearing assembly's from Bamatoy1997 and so far with about 500 Miles on them the growling noise I was hearing is GONE. I also replaced the front brake pads and rotors while doing the bearing replacement.
  20. Oct 7, 2014 at 8:57 AM
    #40
    Sheepshead45
    Sheepshead45 Well-Known Member
    NC
    PreRunner SR5
    my front drivers side crapped out at 90k, far from abused she leads an easy life..
    Last time a wheel bearing went kaput on me was a 70's vintage vehicle. Oh well, otherwise my taco has been rock solid.
