90000 mile service
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ice Chillard, Mar 3, 2012.
  1. Mar 3, 2012 at 7:59 PM
    Ice Chillard
    Ice Chillard [OP] Well-Known Member
    Lifted, exhaust, sound system, tint, rims, wheels.
    How much is a normal price for a 90000 mile service? I'm coming up on it and just want to know how to much to expect to pay.
  2. Mar 3, 2012 at 8:05 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    Over $700 dollars if you do it at the dealership.
    You probably need a tranny flush also b/c of your high miles. That's $230 on top of the $700.
    Parts are only $250 for name brand good stuff if you were to do it yourself. $130ish if you were to shop around a bit :D.
  3. Mar 3, 2012 at 8:21 PM
    Night
    Night Well-Known Member
    Canada
    '11 TRD OR AC MagGrey
    Banks Monster Exhaust, aFe ProGuard 7, 3M Film, UnderCoating, alpine 920 headunit, alpine 6.5 components, 20% tint all around, JL Stealthbox, PDX-V9 Amp, Avid Lightbar, Avid Sliders, Full Metal JackRabbit Tonneau, TRD S/C
    What kind of stuff do you have to do on your 90000 mile service. Hell that is a lot!
  4. Mar 3, 2012 at 8:25 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Ditto.
    It shouldn't be much more than plugs in addition to routine items that should be done regularly.
    20somethingwidataco likes this.
  5. Mar 3, 2012 at 8:40 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch,
  6. Mar 3, 2012 at 8:46 PM
    Bishop2Queens6
    SoCal
    2009 DCSB SR5 4x4
    For me, the major cost is diff fluid. Since I have a 4x4, I'm buying 7 quarts instead of 3.
    Oil and filter-$35
    Spark plugs- $36 ($6 each from the dealership. Copper Denso's)
    Diff fluid- $140 (Royal purple is $20/quart vs Mobile 1 is $9/quart)
    Wiper blades-$25
    For me: $235 for a major service plus miscellaneous like drinks, food.
    Someone else $160ish
    My last dealership mailer quoted a major 30, 60, 90k service for $640, but the nickle and dime you to death with inspection and labor.
    My sister went in for the $30 oil change special, and the total came out to $70 b/c of inspection labor cost, fluid disposal cost, and fluid cost.
  7. Mar 3, 2012 at 11:39 PM
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
    Holly shit that gear oil is so expensive where your at. Not to mention if you change your transfer and front diff to the purple synthetic it stays suuuuper clean. I've changed my rear diff twice now, and the second time it was just as clean as when i put it in (prerunner). Not to mention it's not 4wd all the time. You can buy the copper denso's at the parts store instead of toyota, there not anything special. You can stock up on wiper blades at costco when they do 2 for 1 specials.
  8. Mar 4, 2012 at 12:02 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Why pay double for Royal Purple over Mobil-1?
    GM's factory LSD lube is nicknamed "Grapejuice" and has a purple tint to it. It is supposedly pretty good, but my experience with Royal Purple motor oil in my motorcycle is far less than stellar. It did not perform any better than Mobil-1 V-Twin or 15w50, and it actually underperformed non-synthetic Castrol GTX 20w50
    http://personal.linkline.com/rlockyer/oil/oil.xls
  9. Mar 4, 2012 at 4:27 AM
    Ice Chillard
    Ok so it definitely shouldnt cost more than couple hundred dollars unless I take it to the dealer. That scared me for a second haha
  10. Mar 4, 2012 at 4:46 AM
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2014 TRD Off-Road
    TacoAlaMode Custom grill, SCS Gunmetal F5's, Treadwright guard dogs, King extended travel coilovers w/800# springs, OME Dakars. LRUCA's. Allpro off-road plate rear bumper with high clearance hitch, steel breaded extended brake lines front and rear, SOS concepts bolt on rock sliders with top plate, Pelfreybuilt front plate bumper, rci skid plates, Airflow Snorkel, Tom Woods custom one piece drivesahft, Weathertech in channel rain guards, Bushwacker fender flares, custom cab height bedrack, 60" Hi-Lift jack w/Mount, Recon 10,500lb waterproof winch with synthetic line, rear bumper light pods, front bumper light pods and light bar.
    Do it yourself, there is a reason we call it a stealership.
    Key-Rei and 20somethingwidataco like this.
  11. Mar 4, 2012 at 5:38 AM
    PhishPhryer
    PhishPhryer Well-Known Member
    Lewisberry
    '09 Tacoma SR5
    Definitely DIY. There are great write ups on this site walking you trough everything.
  12. Mar 4, 2012 at 7:45 AM
    Ice Chillard
    I think I just might do it myself. You never really know what their doing anyways.
  13. Mar 4, 2012 at 7:46 AM
    Ice Chillard
    Do you know where any of these write ups might be?
  14. Mar 4, 2012 at 7:50 AM
    elmo7
    elmo7 Easily Replaceable Member
    SC
    07 DC TRD OR 4x4
  15. Mar 4, 2012 at 9:30 AM
    Bishop2Queens6
    SoCal
    2009 DCSB SR5 4x4
    I bought royal purple b/c mobile 1 was sold out everywhere I looked and I wanted to keep it fully synthetic.
    Also denso's at the dealership were the cheapest I found vs the part stores.
    Its expensive living in SoCal
  16. Mar 4, 2012 at 9:58 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I stick with OEM parts where possible, but I normally buy online.
    Claremont Toyota sticks you with "high book" for parts. Glendora Toyota is always 10-25% lower, so it's worth the drive.
    Been 4 or 5 times that I've stopped at Claremont for parts, got the price, and figured "fukkit, I'll go to Autozone"... then went to Glendora and bought there. I no longer even check Claremont.
    But if I'm planning ahead, I'll buy online from Titus-Will or Dallas.
    And I hear ya' on Mobil-1 availability. They can be spotty. When I bought my Duramax was the same time they decided to reformulate the 5w40 Diesel oil. New stock was delayed by 6 months, while old stock was sold out (and at the same time many M1 oils were empty shelves including my motorcycle oil).
    At 10 quarts, and as much as I was driving the Duramax, it became worth it to pay the $20 and become an Amsoil "preferred customer". Cost was still no better than Mobil-1 OTC, but it was available and I could place an order and it was at my door in 3 days.
    Once I got rid of the Duramax and my company was paying for oil changes on the company 4-Runner, it was no longer worth it to buy Amsoil. I'd just stock up on M1 5w30 and V-Twin for the Rav4 and the bike when I saw it in stock.
    Amsoil is good stuff, but it's not worth the premium over Mobil-1 (refer to the chart above)
  17. Mar 4, 2012 at 10:50 AM
    05sctaco
    Ken
    Santa Cruz
    ROCKAUTO, besides shipping the plugs are like $2.50 or something close to that. Same part number too printed on the plugs for the denso's. I can also get NGK at o reilly's
  18. Apr 10, 2021 at 9:18 PM
    Skada
    Skada Well-Known Member
    Carey
    Corral de Tierra, CA
    Tacoma 2015 DCSB
    Wait for it......I was quoted $2400 for my 90,000-mile service at Victory Toyota, Seaside, CA.
    Maybe they are angry at me that I never came back to them after my free services up until 20,000 or 25,000 miles.
    FYI, I was simply curious regarding the cost. I have had fun performing my own services....
  19. Apr 10, 2021 at 9:57 PM
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
  20. Apr 10, 2021 at 10:41 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors TRD ceramic pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS3 Pro (Yellow) Driving lights Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing 4 patches (for now) BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut
    I've only taken my truck to the stealership once. It was for a rear u joint that blew out and I was SOL. They charged me 435 bucks to replace it, and when I went to grease my driveline, the bastards used a non greaseable one. Since then I do everything my damn self. For example, I replaced all 5 u joints and the carrier bearing for 120 bucks, took 5 hours of my time plus the cost of pizza and beer for the people helping me.
