9005 foglights
Discussion in 'Lighting' started by TacoTimmy, Mar 1, 2012.
  1. Mar 1, 2012 at 2:47 PM
    TacoTimmy
    TacoTimmy [OP] Active Member
    Hohenwald, TN
    07 PreRunner SR5
    I noticed that the 9005 lights had similar tabs as the stock 9145 bulb. I figured they would be a little brighter because they do not have the painted end cap. I bought a set of silver star ultras. Turns out they are real close but not perfect. One of the mounting tabs have to be trimmed on the bulb. After I did that they went in and plugged up with no problem. Waaay brighter. Just thought I would share that if you want brighter fogs!
  2. Jan 28, 2013 at 9:55 AM
    3boyztaco
    3boyztaco Well-Known Member
    in the middle of the sea
    PreRunner
    How's the 9005 bulbs working out? Any probs since installing? ie: lens melting, water leaks, wires melting, etc... I'm very interested in trying this setup on my 2010. Thanks.
  3. Jan 29, 2013 at 8:35 PM
    TacoTimmy
    Hohenwald, TN
    07 PreRunner SR5
    Everything is great! No adverse affects. One of the best mods I have done!
  4. Jan 29, 2013 at 9:11 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Except the lack of painted tips is blinding other drivers and neutralizing the beam pattern of the fog light reflector.
  5. Jan 29, 2013 at 11:19 PM
    fyremanpat
    fyremanpat Well-Known Member
    Pat
    757
    2013 DC LB TRD Sport w/Entune
    OME 886x and 5100's all the way around. Toytec AAL. Phillips x-treme vision headlights. 886 reverse lights. Borla exhaust. 20% tint. Hi 6 mod. 285/65/18 Nitto TG on 18" Moto Metal 955's. Airaid intake. Scanguage2.JBA LT's.GC Grill..more to come.
    Pretty sure that black paint isnt doing much...
  6. Jan 30, 2013 at 9:56 AM
    3boyztaco
    PreRunner
    good to hear that. Thanks.
  7. Jan 30, 2013 at 3:16 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    It is shielding the filament from direct view of oncoming traffic.
    Exactly the same reason your headlights have chrome caps in the middle.
    The 9005 is intended to be used as a high beam and not used when there is other traffic in front of you.
    Don't be surprised if you get pulled over for it.
