90k miles and im done
Discussion in '4th Gen. Tacomas (2024+)' started by Taco001, Jan 2, 2025.
  1. Jan 2, 2025 at 8:32 AM
    Taco001
    Taco001 [OP] Well-Known Member
    24 OR
    So i love my 2024 Taco but i have no plan to keep her beyond 90k miles or so. I just dont think this 4 banger drivetrain will last much beyond that without major repair bills. I mean the engine is already noisy i cant imagine how loud and rattily this thing will sound like at 80k miles. How long or how many miles does everyone plan on keeping thiers?
    GTGallop likes this.
  2. Jan 2, 2025 at 8:39 AM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    Friday never hesitates…
  3. Jan 2, 2025 at 8:41 AM
    foeix
    foeix 24 TRD OR 6MT
    Have you owned a Toyota that got progressively noisier as it ages? My 1FZ-FE and 3UR-FE sound the same at 250K miles as they did at 50K miles. I expect the T24A-FTS will age similarly.
  4. Jan 2, 2025 at 8:45 AM
    IdahoYota
    IdahoYota Well-Known Member
    Idaho
    '24 Trd Sport
    More than I need but still not enough.
    Seems a little premature to make that decision now. Unless you're nearing in on 90k miles and having issues.
  5. Jan 2, 2025 at 9:11 AM
    Taco001
    24 OR
    Yes, it does seem premature but this aint my first rodeo in a 4 cylinder. The typical progression as milage piles up. 0 to 50k typically no issues, 50k to 100k the engine gets louder and more rattily sounding, 100k to 150k is where the real problems typically begin. This phase is what i call the nickel an dime phase and includes failures of the interior equipment and electronics, slowly but surely, one by one. All automobiles suffer failure at some point, just a question of when.
  6. Jan 2, 2025 at 9:32 AM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Is this your first Toyota? I'm on my 2nd, they are noisy...it is what it is. The first one, I only did regular maintenance until about 160k, then the fuel pump went out and I had to rebuild the driveshaft. Sold it at 197k. The current one is at 126k. Just replaced the driveshaft and fuel pump. The A/C pump went bad this past summer also...but this truck plays a lot harder than the first.
    Still, the engines are solid, for the most part. I do share the apprehension on the turbo-4, but manufacturers have come a long ways in the past 30 years.
  7. Jan 2, 2025 at 9:47 AM
    tjdasaurus
    tjdasaurus Member
    Tyler
    Supercharged 2001 Tacoma
    offroad bumper, android auto headunit with backup camera, TRD supercharger, URD 7th injector kit
    Im going to keep my 4th gen as long as possible. All this speculation about the reliability of the 4th gen engines is pointless at this moment in the 4th gen life cycle, we just simply don't know. I'm hopeful this engine will last like the rest of them as it was designed from the ground up to accommodate the turbo. This isn't the 90's where we are slapping turbos on any engine we can...we've come a long way since then. Engine knock and thus keeping engine temps under control at high pressures is the biggest issue to contend with on forced induction engines. The coolant lines on these engines are fucking huge, indicating to them that they thought that through. Time will tell, though... crossing my fingers!
    Fast1 and gargamel05 like this.
  8. Jan 2, 2025 at 10:13 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The 1.6 Million mile Tacoma had a 4 cylinder engine in it. Two actually. The 1st one needed a head gasket at 900,000 miles so they replaced it with a scrap yard engine with 100,000 miles already on it. Then drive it another 600,000 miles. Truck was still running when the owner died.
    The turbo is new to Tacoma, but others have been using them for a while. If Ford can put a 2.7L turbo in a 1/2 ton and make it work, I'm sure Toyota can figure it out.
    wi_taco, Kolter45, gargamel05 and 2 others like this.
  9. Jan 2, 2025 at 10:18 AM
    TeeYoda
    TeeYoda Well-Known Member
    PNW
    2003/2025 Tacoma sr5 4x4
  10. Jan 2, 2025 at 11:05 AM
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    An inline 4-cylinder is a hell of a lot simpler than a V-block engine. Plus, this motor turns a lot slower than the old V6, which means much less wear.
    So... keep cogitating.
  11. Jan 2, 2025 at 11:26 AM
    tjdasaurus
    tjdasaurus Member
    Tyler
    fo real ... when you open the hood on a 4th gen the spark plugs are practically begging you to service them. Pain in the ass to swap out spark plugs on my 1st gen v6
    Sagebrush[QUOTED] likes this.
  12. Jan 2, 2025 at 11:35 AM
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    If you look at ditching it, try to before 60 or 80 thousand miles. If I recall those are depreciation points.
    Someone showed me that if you don't sell a car by 80K then you need to plan on keeping it until you can donate it for scrap to the Kidney Foundation. That's like 400K for a Toyota.
    TACOTU3 likes this.
  13. Jan 2, 2025 at 11:42 AM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    Buys new truck.
    Preemptively trash talks new truck because said new owner knows new truck won’t last.
    What a time to be alive.
  14. Jan 2, 2025 at 11:44 AM
    usmc2msu
    usmc2msu Well-Known Member
    TJ
    2017 SR5
    The used market for Tacoma’s is not following that belief though. Which is great!
    DavesSR5 likes this.
  15. Jan 2, 2025 at 11:46 AM
    MGMDesertTaco
    I've got 63k on my 2017. It just turned 9 years old a couple of days ago. :hbd::rofl:
  16. Jan 2, 2025 at 11:47 AM
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    I'm keeping mine forever!
    TacoTime55 and Red Archer like this.
  17. Jan 2, 2025 at 11:47 AM
    Booman
    Booman Well-Known Member
    Indiana
    2024 Tacoma TRD Sport
    Anyone close to the 90000 mark?
  18. Jan 2, 2025 at 11:51 AM
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
    Be proactive, sell it now.
  19. Jan 2, 2025 at 11:55 AM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    Why don't you keep it until something breaks, then fix it and keep driving like a normal person?
    Why does this website bring out the most bizarre and loudest opinions on vehicles from the uninformed?
    Why did you buy the POS?
  20. Jan 2, 2025 at 11:57 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    What’s the milage ? I do agree I don’t see long reliability with these 4cyl engines since they are turbo charged and produce more heat . Would loved to have seen a 6 cylinder in these new trucks . The 4 should have stayed with the sr model .
