90k service...be gentle, automotive newbie here
Discussion in '2nd Gen. Tacomas (2005-2015)' started by coffee_brake, May 30, 2020.
  1. May 30, 2020 at 10:59 PM
    coffee_brake
    coffee_brake [OP] Member
    Jenn
    2014 plain-Jane 2.7
    nottadam thing
    I just got a '14 2.7 base model 2WD 5-speed and there's no owner's manual in it. It just turned 89k miles.
    1) Is there a big service scheduled at 90k?
    2) What parts of it do I need to check for real?
    Here's my skill level: above-average level motorcycle maintenance and repair but extremely basic cage (4-wheel car or truck) experience. I can rebuild the top end and carb rack on a bike but the most I've done with a truck beyond oil changes is new ball joints and AC compressor.
    I am lost looking at most of the threads here, I don't know what they're about or if they even apply to my truck. I don't know the acronyms. I'd appreciate some timely PMCS or preventative maintenance tips.
  2. May 30, 2020 at 11:06 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If nothing has ever been done, I’d opt for
    spark plugs
    Coolant
    Transmission fluid
    Rear differential fluid
    And serpentine belt
    Call it a day and carry on your way.
    Also, You can get the Owners and Service Manuals - Free from the Toyota Website.
    Google - “Toyota Owners Manual” the Toyota site should show up.
    Choose your year and model, then download the manual.
    coffee_brake[OP] likes this.
  3. May 30, 2020 at 11:07 PM
    coffee_brake
    Jenn
    2014 plain-Jane 2.7
    nottadam thing
    Sweet....um...remember I'm ignorant, do I have Transmission fluid in a stick shift?
  4. May 30, 2020 at 11:08 PM
    TnShooter
    Deogee
    STOCK
    And if your truck has a cabin filter, definitely check it.
  5. May 30, 2020 at 11:09 PM
    coffee_brake
    Jenn
    2014 plain-Jane 2.7
    nottadam thing
    WTF IS A CABIN FILTER?! ok I reckon I can figure out what it is. Where is it?
  6. May 30, 2020 at 11:13 PM
    Artruck
    Artruck Well-Known Member
    Lawrence, KS
    '09 Super Basic
    Cabin filter is in the glove box, your transmission takes oil change on a schedule like the motor and the axle.
  7. May 30, 2020 at 11:14 PM
    TnShooter
    Deogee
    STOCK
    Yes, although the proper term is “gear oil”
    It filters the air inside the truck.
    It’s usually located behind the glove box.
    If you download the Owners Manual, it is in there Under Air Conditioning Filter.
    It even shows you how to change it.
  8. May 30, 2020 at 11:16 PM
    coffee_brake
    Jenn
    2014 plain-Jane 2.7
    nottadam thing
    OK gotcha. I need the specs on this. My bikes are unit construction: the transmission is in the same body as the motor so one oil change does it all. I'll dig into the manual download and hope it tells me what to do.
    Would a Haynes manual be a good idea? Or is it all pretty much straight-forward without the book?
  9. May 30, 2020 at 11:17 PM
    Artruck
    Lawrence, KS
    '09 Super Basic
  10. May 30, 2020 at 11:19 PM
    TnShooter
    Deogee
    STOCK
  11. May 30, 2020 at 11:20 PM
    Artruck
    Lawrence, KS
    '09 Super Basic
    Yeah, same process for any manual, and same oil for the 5 speed. Just way more 4.0 6 speeds on here so it was easier to find.
  12. May 30, 2020 at 11:23 PM
    coffee_brake
    Jenn
    2014 plain-Jane 2.7
    nottadam thing
    thank you! very clear!
  13. May 30, 2020 at 11:31 PM
    Artruck
    Lawrence, KS
    '09 Super Basic
    TnShooter likes this.
  14. May 30, 2020 at 11:38 PM
    coffee_brake
    Jenn
    2014 plain-Jane 2.7
    nottadam thing
    Thanks for links. And yep, that's my Connie, over 100k on it since I got it new.
  15. May 30, 2020 at 11:41 PM
    Artruck
    Lawrence, KS
    '09 Super Basic
    love those things. Always tempted by them on Craigslist and at swap meets. Under appreciated by everyone. Fellow Kawasaki rider here
  16. Jun 1, 2020 at 7:10 PM
    po35042
    po35042 Well-Known Member
    Patrick
    Tuscaloosa, AL
    2021 SR 4x4 DCSB
    As for Manual Trans oil, I put Redline MT-90 gear oil in my 2.7 Tacoma 5 speed and it smoothed it out a good bit.
    You'll need 2.3 qts. for the 5 speed and a 24mm socket or wrench (preferably 6 point, the plugs are half height and round off easily).
  17. Jun 1, 2020 at 9:42 PM
    Honorius
    Honorius Member
    2005 Speedway Blue X-Runner
