90k Timing Belt Replace Recommended parts to replace while I'm in there?
Discussion in '1st Gen. Tacomas (1995-2004)' started by License2Ill, Feb 12, 2014.
  1. Feb 12, 2014 at 8:19 PM
    License2Ill
    License2Ill [OP] Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Time to do this job.
    So far I'm ordering:
    • Waterpump
    • A/C Belt
    • P/S Belt
    • Timing Belt
    • Altenator Belt
    • Thermostat
    • Water Inlet Gasket
    • Tensioner
    Any thing else that I should get?
    TIA
  2. Feb 14, 2014 at 7:28 AM
    License2Ill
    Ian
  3. Feb 14, 2014 at 7:34 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    does anything else need replaced?
    if not then don't bother
    my water pump needed replaced so I did that while I was in there.
    maybe plugs/wires if you haven't changed them?
  4. Feb 14, 2014 at 7:43 AM
    CLOUDL1GHT
    CLOUDL1GHT Well-Known Member
    Garrett
    North Houston
    2023 Tacoma SR
    That's pretty much it. I'm about to do all that at 150,000mi
  5. Feb 14, 2014 at 7:43 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Looks like you have it covered, water pump is a great idea even if its not leaking yet. Plug wires have nothing to do with that repair lol, he is talking about related items that might as well be done while he is in there. I did see some suggest cam seals but at 90k you should be fine until the next timing belt
  6. Feb 14, 2014 at 7:44 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Depending on shape id replace radiator hoses also just to be safe.
  7. Feb 14, 2014 at 8:05 AM
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
    As stated above replace them hoses and clamps. Your going to drain the coolant to do pump right. Also make sure to use the correct coolant don't mix the green and red..
  8. Feb 14, 2014 at 10:46 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    my suggestion was aimed at if the OP hadn't done them yet or not in the last maintenance period when they should have been done.
    I didn't change my plugs until the 90k mark when i did all the other stuff :p
  9. Feb 14, 2014 at 5:49 PM
    License2Ill
    Ian
    Thanks for the replies!
    So in addition to the parts I listed I went ahead and ordered the rad hoses and cam seals. Doubt I'll need bearings.
    I know my battery cables are newer-ish, not sure how new. PO installed those.
    But ordering spark plugs! Not sure when they were last replaced...
    Thanks again!
  10. Feb 15, 2014 at 6:32 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Only 90K on the idler pulleys? hmm. Check them out when you have it apart. Push in on the face and turn that bearing very slow,,try and feel for hops and skips,,gritty shit,, dryness,,ect. Reverse the procedure by pulling on the face of the pulley. Good import bearings in there,,but doesn't hurt to keep track. Captain Obvious says that any extended belt squeal at all means bad juju. Cut the old belt varnish off of the pulley ribs and sides with Gumout or denatured alcohol,,or your favorite. Some will scuff those pulley face areas lightly with some Emery cloth, 60gr. For better bite.;). Some will blast and repaint the pulleys. The belts can stretch a bit after a few hrs of run in.
  11. Mar 18, 2014 at 11:34 PM
    License2Ill
    Ian
    Thanks Mod.
    The tensionier pulley was going out. The other pulley between the cams had left a layer of medal dust on the timingbelt cover, so while apart I ordered all three. :( Cleaned the cr/shaft pulley. Thanks for the info.
  12. Mar 19, 2014 at 6:11 AM
    CR, WA
    stock
    Cool.
    Save it for a backup for 6 mo, in case the new one decides to crap out.
    The rad hoses and clamps was definitely a good add on. Spare hoses also.
    Your new belt lined up on the new pulley like it should?. Have seen some incorrect offset replacement pulleys recently. I think they are mashing the bearings in to hard when they rebuild those spendy units. Had a couple wobbler's on different rigs lately.
  13. Mar 19, 2014 at 10:00 AM
    License2Ill
    Ian
    Wobbley pulleys? Were they toyota or aftermarket? I got all oem stuff, so hopefully it'll all last at least til the next t belt change.
    It all lined up as it should, it was a bitch getting the last part of the belt to line up on the crankshaft.
  14. Mar 19, 2014 at 3:03 PM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    I'm glad you posted your list. I'm about to order parts to do mine.
    What's "Water Inlet Gasket"? Is that the water pump gasket?
  15. Mar 19, 2014 at 6:35 PM
    CR, WA
    stock
    Aftermarket for Toyota and GM. 3 different idler pulleys. I fixed one on a arbor press,,the other two went back.
    You should be gold with the oem stuff.
    I always keep a keen eye on all the stuff I checked or touched during and after a coolant deal.
  16. Mar 20, 2014 at 8:39 AM
    License2Ill
    Ian
    It showed up on a part diagram, but i didnt find it when i had the waterpump off.
    So im guessing it wasnt for my engine.
    The oem waterpump came with all the needed gaskets.
