'91 Hilux with destroyed motor
Discussion in 'Hilux' started by REB42, Jul 5, 2021.
  1. Jul 5, 2021 at 6:36 PM
    REB42
    REB42 [OP] Member
    I have a 1991 Hilux which ran great until the gasket blew and my partner drove it with a blown gasket. That destroyed the motor.
    I replaced it with a 1996 Tacoma and I'm not sure what to do with my Hilux. Do you think it's worth it to have the motor replaced before selling it? Or just sell it as is?
  2. Jul 13, 2021 at 7:43 AM
    Yer Grandpa
    Yer Grandpa Member
    Brock
    1991 Toyota Hilux SR Dbl Cab LN107
    How the frame and body? You could part it out or sell as is. I may be interested in some parts if is in good shape.
    gotoman1969 likes this.
  3. Jul 13, 2021 at 7:46 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    What engine?
  4. Jul 13, 2021 at 10:22 AM
    REB42
    REB42 [OP] Member
    The frame and body are in great shape. It was a fantastic truck until the gasket blew and my ex tried to drive it home.
    Slashaar and Yer Grandpa like this.
  5. Jul 13, 2021 at 10:23 AM
    REB42
    REB42 [OP] Member
    It's a V6, 4 wheel drive, extended cab.
  6. Jul 13, 2021 at 10:26 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    It’s worthless. I wouldn’t bother fixing it. I’ll help you out and take it off your hands so you don’t have to deal with it.
    Taco 422, Mully and Slashaar like this.
  7. Jul 13, 2021 at 10:28 AM
    REB42
    REB42 [OP] Member
    Gee. Thanks, Joe.
  8. Jul 13, 2021 at 10:37 AM
    jowybyo
    Joe
    Baltimore, MD
    I’m just trying to help.
  9. Jul 13, 2021 at 10:40 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    What makes the engine destroyed out of curiosity? And why won't a new head gasket fix it?
    Slashaar and REB42[OP] like this.
  10. Jul 13, 2021 at 10:56 AM
    CPS-65
    CPS-65 I’m good for some, but I’m not for everyone.
    Alta Loma, CA
    2019 Quicksand TRD Off Road 4X4
    Mostly old man mods
    The V6 for that year has head cracking problems. The engine may have hydrauliced from pulling in coolant. They were also pretty underpowered and got poor mileage. We used to have a 91 4Runner that had the same issue. I don’t think the engine is likely worth rebuilding if it had a catastrophic failure. You might check with a couple of remanufacturers if you are changing the engine yourself and you think the core is usable. If you are paying someone else to do it all, I think you will have more into it than it’s worth. The only way it would make sense is if you are going to drive it for the next 4 or 5 years.
    Another idea would be the use of a later V6 which are good engines. I’m sure the swap would have its own set of challenges.
    Pickeledpigsfeet likes this.
  11. Jul 13, 2021 at 11:06 AM
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    Where are you located?
    The 3.slow in your truck is arguably the worst motor toyota put in a truck. I have owned 3 of them and have done headgaskets and heads on 2 of them and a 3.4 swap on the 3rd. You will pay more than its worth for a motor and to have someone swap it. When people talk aboit the crazy market on old toyota trucks they really mean anything powered by a 20r/22r/22re.
  12. Jul 13, 2021 at 11:11 AM
    REB42
    REB42 [OP] Member
    This is a helpful discussion. I appreciate all these answers.
    I'm in the Bay Area in Northern California.
  13. Jul 13, 2021 at 11:16 AM
    REB42
    REB42 [OP] Member
    I don't have the skills to fix it myself. So from these replies it sounds like it wouldn't be worth paying someone to fix it. Yes?
    Slashaar likes this.
  14. Jul 13, 2021 at 11:29 AM
    CPS-65
    Alta Loma, CA
    Mostly old man mods
    If you were going to drive it for several more years it might be depending on the rebuild cost. If you are going to flip it, no, cut your losses. Also consider your trans and axels will also need rebuilding at some point. It may just nickel and dime you. You have to consider the cost to fix and operate it vs the cost to replace.
  15. Jul 13, 2021 at 1:27 PM
    gotoman1969
    You can get 5k all day for that with the blown motor. I just a quick search. 6 91s 100k -175k miles all v6s. $13k-20k!! Crazy. If it’s as good a shape as you say it is. I’d drop 5-6k in a motor into it.
  16. Jul 13, 2021 at 1:36 PM
    gotoman1969
    Technically it’s not a Hilux as they have never been available in the U.S. But if you have the cash it might be worth fixing. Could do a SAS and make an awesome project truck too.
    CPS-65 likes this.
  17. Jul 13, 2021 at 6:50 PM
    REB42
    REB42 [OP] Member
    If not a Hilux, what would you call it? Since it's not technically a Tacoma either.
  18. Jul 13, 2021 at 6:54 PM
    REB42
    REB42 [OP] Member
    Really? $5k even with a blown motor? I had hoped for something like that, but thought it was wishful thinking.
    I do live in an expensive area of the country, so maybe...
  19. Jul 13, 2021 at 6:54 PM
    Yer Grandpa
    Yer Grandpa Member
    Brock
    They were just called a Toyota pickup
    gotoman1969 and RedWings44 like this.
  20. Jul 13, 2021 at 6:55 PM
    RedWings44
    Michigan
    Back then it was just called the Toyota Pickup I believe. There was also the T100, but I believe that was different. I just wasn't sure if you imported a Hilux or were from elsewhere other than the US.
    Yer Grandpa likes this.
