91 octane?
Discussion in '5 Lug' started by adam2180, Jan 8, 2012.
  1. Jan 8, 2012 at 4:53 PM
    adam2180
    adam2180 [OP] Well-Known Member
    Dartmouth NS Canada
    2010 SR5 Double Cab
    Is it worth while using 91 octane gas in my 5 lug?
  2. Jan 8, 2012 at 7:29 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    i doubt it will make much of a diference with such a small engine with no upgrades. but try it if you want? :confused:
  3. Jan 8, 2012 at 7:32 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    It wouldn't hurt, at least your wallet will be a bit lighter.
  4. Jan 9, 2012 at 12:00 PM
    adam2180
    Dartmouth NS Canada
    2010 SR5 Double Cab
    I have always used it because I have been told its cleaner gas.
  5. Jan 9, 2012 at 12:01 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    I've got ocean front property in Arizona I'd like to sell ya. ;)
  6. Jan 9, 2012 at 2:21 PM
    adam2180
    Dartmouth NS Canada
    2010 SR5 Double Cab
    I'm listening.......
  7. Jan 15, 2012 at 4:48 PM
    adam2180
    Dartmouth NS Canada
    2010 SR5 Double Cab
    I filled it up with regular and didn't notice any difference.
  8. Jan 16, 2012 at 1:11 PM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    The computer on the 4.0 engine differentiates between octane and adjusts its performance accordingly. THe 2.7's computer does not. Any octane in excess of 87 is wasted money.
  9. Jan 16, 2012 at 1:40 PM
    adam2180
    Dartmouth NS Canada
    2010 SR5 Double Cab
    Yup, I'm a believer... Or a non-believer, you know what I mean.
  10. Jan 22, 2012 at 8:06 PM
    emt49126
    emt49126 Member
    Rodney
    Kentucky
    Tacoma
    Thank you. I put high octane in the other day. Needless to say, I complain that it costed me 30.00 for less then 9 gallons. What is your thoughts on gas additives?:confused:
  11. Jan 22, 2012 at 10:19 PM
    the.sight.picture
    the.sight.picture Well-Known Member
    Nick
    Warren County VA
    2018DCSB TRD Quicksand
    Emu 887x Nitrochargers Dakar Heavys, 255 85 16 ST-MAXX
    im pretty sure its 89 octane if u are running the v6. I can tell the differance when driving...much less torque
  12. Jan 22, 2012 at 11:09 PM
    VanCity4x
    VanCity4x The shit show
    DJ
    BC
    05 Prerunner SAS
    3link 1tons on 40's and sum stuff
    I get 3+ mpg better using 91 on my 4.0. Ive been told the same thing. Wouldnt make a difference in 2.7L
  13. Jan 22, 2012 at 11:27 PM
    Desert Rat
    Desert Rat Well-Known Member
    Monterey, California
    2012 Tacoma DCSB TRD Off Road Double Cab
    3" OME lift, Avid lightbar and sliders, PIAA 525s, custom Baja Rack, SnugTop with Windoors, PopnLock tailgate, power moonroof, ARB awning, Pioneer AVIC-Z140BH, Alpine amp, Pioneers speakers, custom subwoofer.
    Interesting...
  14. Jan 22, 2012 at 11:30 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    No. Search for the other threads present on the subject and read for days.
  15. Feb 18, 2012 at 11:53 AM
    lmikk12
    lmikk12 Active Member
    Big Bear, CA
    12 Tacoma 5 Lug
    Sorry if i am a little late on this but octane ratings on fuel is how they stand up to pressure and heat before igniting themselves,with a higher compression ratio you have to run higher octane fuel so there is no detonation. higher octane fuel will not give you any more power if that is what you are looking for.However using a lower octane fuel can cause preignition or detonation or "knocking" that is small enough that you won't feel it but enough for your motor to retard the timing to save itself, this results in lower mpg's and less power. all it takes is one very small ping, so 89 or 91 would be more of a preventative measure than anything else. This can happen in any motor high compression or low even with higher octane fuel, but its what 3 bucks a fill up, why not.
  16. Feb 18, 2012 at 12:56 PM
    2010TRDtaco
    2010TRDtaco Well-Known Member
    James
    Oklahoma, muskogee
    2012 TX baja DCSB AT barcelona red
    Warn winch, body armor rear bumper, 2x yellow top optima, color matched wheel bead, weather tech mats, ams oil everywhere, De-badged, hard wired radar detector, rear diff. breather extension, k+n, fog light any time, trailer wiring relocate, iridium plugs, LED grill marker lights,
    Only use what your owners manual says, higher octane in a vehical not made for it will cause a build up in the combustion chamber and will eventually make the engine knock
  17. Feb 18, 2012 at 1:06 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    In my 2005 manual it says for best performance use 91:notsure:
  18. Feb 19, 2012 at 8:22 AM
    lmikk12
    Big Bear, CA
    12 Tacoma 5 Lug
    Really, did it say why? i have never heard of anything like that.
  19. Feb 19, 2012 at 8:31 AM
    lmikk12
    Big Bear, CA
    12 Tacoma 5 Lug
    I can see what you are trying to say but but carbon deposits are not cause by higher octane fuel they are either caused by a rich air/fuel ratio or oil consumption. but over time carbon deposits can make you vehicle knock.
  20. Feb 19, 2012 at 8:45 AM
    1TUFFTRD
    1TUFFTRD WTF
    06 AC with a skewp
    06 With a Skewp.
    That's why I said my 2005
