91 on the 2.7?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blanktaco, Mar 5, 2011.
  1. Mar 5, 2011 at 7:08 PM
    blanktaco
    blanktaco [OP] New Member
    Arvin
    Los Angeles
    '11 PreRunner SR5
    2.7 on 91 gas what do you think? bad? I did it recently and on a 90 mile drive back it smelled like gas in the car once in a while.Its a 2011 prerunner acess cab btw. Thanks guys
  2. Mar 5, 2011 at 7:21 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    No point in it . I'd suspect another problem, if you smell fuel in the cab, anything from a car in front of you, to a leak in yours.
    Fwiw , ive never smelled gas in mine on 87 ,or 89 when i ran it occasionally.
  3. Mar 5, 2011 at 7:26 PM
    blanktaco
    Arvin
    Los Angeles
    '11 PreRunner SR5
    Do you notice a difference between the 87 and 89 use?, mpg, power,etc?
  4. Mar 5, 2011 at 7:41 PM
    Tacoyota
    08 4wd
    I didnt think I would, but it seemed to run smoother , otherwise no difference in power or mpg that i could tell.
  5. Mar 6, 2011 at 6:24 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I wouldn't, the 2.7 is designed to run on 87. Anything else would be a waste. The 4.0 is designed to run best on 91 and I do notice a difference in throttle response and MPG over the 87 on mine.
  6. Mar 6, 2011 at 6:24 PM
    joes06tacoma
    Joe
    Central Coast, CA
    X2 on there being something else making the smell.
