92 octane gas
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Boss hoss, Aug 28, 2019.
  1. Aug 28, 2019 at 2:58 PM
    SpeySquatch
    2016 TRD OR DCSB
    Not sure I read correctly. Bike?
  2. Aug 28, 2019 at 4:25 PM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    I don’t believe that’s true. 87 octane contains more BTUs than 91 octane fuel per gallon.
    MaTaco_4x4 likes this.
  3. Aug 28, 2019 at 4:32 PM
    SDTaco4x4
    SDTaco4x4 Well-Known Member
    San Diego
    2016 Black TRD Sport 4x4
    Yep, I switched to premium a few tanks ago, and the difference is very noticeable.
    I haven't noticed any power difference, but the engine runs smoother and I get better MPG.
  4. Aug 28, 2019 at 4:40 PM
    24-7
    24-7 Well-Known Member
    Phil
    Florida
    16 TRD OR 4Door 6MT
    Driver, KO2's, Open Y-Pipe
    I get more out of a tank with 90 non-ethanol than any other pump gas. I put 5 gallons of 114 in the other week. That just made the exhaust smell good.
  5. Aug 28, 2019 at 7:30 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Last week I filled with 93 and didn't notice anything different throughout the week. Today I went back to 87 because I felt it wasn't worth the extra money to feel the same. Maybe every once in a while I'll fill up with Shell vpower to do a little cleaning but won't be often, if at all. I always just make sure it's top tier gas every time and have no issues.
  6. Aug 28, 2019 at 8:23 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Show me please. It might be like two btu's out of 11,000 or something. Not anything worth mentioning. Octane is not something used to increase power.
  7. Aug 28, 2019 at 8:35 PM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    Higher octane fuel absolutely makes a difference. Anyone who claims otherwise does not have a full understanding of modern engines.
  8. Aug 28, 2019 at 8:42 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Yes it makes a difference but it has no appreciable additional energy per gallon of gasoline. What it does is allow the timing to be automatically changed in your vehicle because knock sensor, which at wide open throttle, will allow a few more horsepower.
  9. Aug 28, 2019 at 8:56 PM
    Doggman
    Alabama
    2017 TRD OR MT
    Correct. The difference, specifically with respect to produced power, is likely most significant at WOT however it is not isolated to it. Different octanes allow for different ignition timing across the entire throttle map.
    TheCowWatcher and hiPSI[QUOTED] like this.
  10. Aug 29, 2019 at 4:37 AM
    MaTaco_4x4
    MaTaco_4x4 Well-Known Member
    2018 Tacoma Sport DCLB
    Bicycle (aka bike: any vehicle that runs on two wheels). In my case, a Ducati 1098S.
    You might be confusing motorcycle culture with Harley culture, two very different things. Harley riders, glorified by Hollywood and Broadway, use different slang-ish terms for bikes much like trendy homosexuals might do with objects or people e.g., "hog" vs "bike", "girlfriend" vs "numbnuts", etc.
    When someone is insecure about something, say, their sexual orientation, the first indications of that will be in their choice of euphemisms/slang. There's nothing wrong with that, I'm totally serious.
    But yeah, "bike' is a commonly understood and correct term in performance motorcycle circles.
  11. Aug 29, 2019 at 5:03 AM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    What seems to be most commonly available here locally is 87, 89, and 93 octane.
    For several years now I've been using the 89 octane in all my vehicles. I have occasionally used either the 87 or 93 octane.
    I honestly could not tell any difference. :anonymous:
    That, and this thread, makes me wonder why I keep paying extra for the mid-grade. :notsure:
    Old habits die hard.
  12. Aug 29, 2019 at 7:49 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    I've always said that you should put in what was recommended by the manufacturer for your vehicle, but I agree with the truck running better on premium. It's not as noticeable to me near sea level, but going through the mountain passes or with a heavier load I definitely notice that it runs better and gets a little better mpgs while doing so.
    I did the math comparing several tanks on regular vs premium, it's still cheaper to run regular even with worse mpgs because of the cost of premium, but the cost is worth it to me.
    nomnomtaco and bshammer0[QUOTED] like this.
  13. Aug 29, 2019 at 8:20 AM
    Boss hoss
    Boss hoss [OP] Well-Known Member
    Richard
    Silverton Oregon
    2021 TRD OR premium access cab.
    Carpet bed liner and Matt, fuel wheels KO 2 tires. Bilstein 6112,5160 frt. lift .white with black leather seats.
    I agree that its a waste to run more octane than the motor needs but i kid you not it changed the dead spot in the throttle from the first 1/2 inch or so of almost nothing to driving like the ECT is on and i have tried it both ways now and other than the shifting faster in ECT mode its feels the same driving around town. I am running 92 oct. from now on. May try the none ethanol gas. My 500 hp. Mustang runs better on 93 ethanol gas than it does on non and that is a 1/4 testing. I remember the chevron 102 octane that my corvette needed with 11 to 1. With lots of lead needed for the valve seats and no ECM bad a lot of knocking if you didn’t run it. I feel the power difference with the 92. Enough said.
    Junkhead and bshammer0 like this.
  14. Aug 29, 2019 at 8:31 AM
    SpeySquatch
    2016 TRD OR DCSB
    WTF are you talking about? o_O
    Blue Truck likes this.
  15. Sep 1, 2019 at 4:08 PM
    #35
    Boss hoss
    Richard
    Silverton Oregon
    I believe the 87 oct. re-tarts the timing and the 92 advances it. I have used 1/2 tank of the 92 now and well fill again with it. It shifts very good now and stays in 5th until 62 mph or when you let off of a easy throttle. My truck and i have bonded now. Grin
    nomnomtaco and Junkhead like this.
  16. Sep 1, 2019 at 4:47 PM
    #36
    Boss hoss
    Richard
    Silverton Oregon
    Very well stated . Thanks
    TheCowWatcher likes this.
  17. Sep 1, 2019 at 5:52 PM
    #37
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    This could be a logical explanation. If you're familiar with motorcycle and/or atvs, one of the performance enhancing mods is doing a timing advance as the timing is using retarded for emissions purposes from the factory. Advancing it gives u more power.
    nomnomtaco likes this.
  18. Sep 2, 2019 at 5:59 AM
    #38
    Boss hoss
    Richard
    Silverton Oregon
    The new engines have a anti knock sensor which retards the timing when pre-ingintion occurs. Higher octane is needed with 11-1 compression. Its a sales gimmick i think. My 435 hp mustang is not happy on regular gas but the manual says it can run on it just not very well.
  19. Aug 12, 2022 at 9:26 AM
    #39
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    no, i guarantee you there's a real difference once the ECU adjusts the timing advance
    Junkhead likes this.
  20. Aug 12, 2022 at 9:38 AM
    #40
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Throw back
    Vegasstunts likes this.
