92 Octane
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bwarnicke, Jul 17, 2019.
  1. Jul 17, 2019 at 5:43 PM
    bwarnicke
    bwarnicke [OP] Active Member
    Brian
    2016 Tacoma
    Has anyone noticed any difference in MPG or HP running 92 Octane? I was thinking about trying 92 while towing our travel trailer over a Mountain pass.
    Thanks!
    Brian
  2. Jul 17, 2019 at 5:46 PM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    I got slightly better mpg with premium. It also eliminated the pinging when going up hills before it downshifted.
  3. Jul 17, 2019 at 6:12 PM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    I switched from 87 to 93 for a bit. The biggest difference I noticed was on highway performance. Much better ability to hold gears and power through small inclines.
    MPG difference was negligible, and there's so many other factors to account for anyway.
  4. Jul 17, 2019 at 6:13 PM
    camillethetoy
    camillethetoy Just a Minor Threat
    jeremy
    KCMO
    98 T100
    I heard it's not supposed to (from Salesman), but I'm pretty sure mine runs much better on premium. I've only tried it on 2 tanks out of 5,500 miles, worth a shot to try!
  5. Jul 17, 2019 at 6:15 PM
    TacoMamba35
    PNW
    Yes. Not cost effective, but I enjoyed the slight performance gain, whether it was a placebo or not.
    camillethetoy and NMTrailRider like this.
  6. Jul 17, 2019 at 6:17 PM
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    I did the same while towing 3500+ lbs. Started a half tank before and then filled up before leaving. A little more grunt according to my butt dyno.
  7. Jul 17, 2019 at 6:38 PM
    BSFord
    BSFord Well-Known Member
    2018 TRD Sport 4x4
    Clazzio PVC Seat Covers Dashcam install TRD Pro Grill MESO Total Tail Stage 1 Tailgate Lock vled total interior light upgrade TRD Pro Shift knob N2 Designs Autostart w/ smart phone module
    There is no additional power in higher octane, that's a fact. At higher altitudes it's even less necessary.
  8. Jul 17, 2019 at 7:18 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Run you vehicle on the octane it’s meant to be run. Higher octane fuel is slower burning, which is why the pinging, and few other things mentioned here go away. But running higher octane fuel can also cause premature buildup of carbon on valves and pistons if you vehicle is meant to run on lower octane lime 87.
    BSFord, camillethetoy and stun gun like this.
  9. Jul 17, 2019 at 7:26 PM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    In for the quasi-scientific-domesticated-posting from his wife’s knitting room-bro science. About the fuel for a Japanese pickup truck.
    NMTrailRider and Junkhead like this.
  10. Jul 17, 2019 at 7:41 PM
    skierd
    skierd Well-Known Member
    David
    Fairbanks, AK
    2021 F150 XL STX Screw 4x4 2.7
    My truck runs significantly better on 90 (best we get in Alaska) vs 87. Throttle response from a stop is better, shifting is less wonky, and transitional throttle response in particular is much better, and it drives much better both around town and in the hills on the highway. I get 1.5-2mpg better in all-city driving and about the same mpg on the highway (where i assume MPG is aero limited more than anything else).
    My best guess? The engine has pretty high static compression, and Toyota uses lots of tuning adjustments (ignition timing, cam phasing, fuel timing, and whatever else) to make 87 octane work. Running higher octane of course means you’ll have less ECU wizardry making the engine survive, letting it run cleaner. It takes several tanks of premium to get the full drivability effects in my experience, which makes sense if the ECU is relearning based on knock conditions, etc. Conversely it only takes a tank or three of 87 to lose the gains.
    At $3.00 for 87 and $3.25 for 90 the mpg bump more or less covers the cost and the truck drives so much better that it’s worth it for me.
    nomnomtaco and NMTrailRider like this.
  11. Jul 17, 2019 at 7:47 PM
    ET340f
    ET340f Well-Known Member
    Westechester, NY
    2019 OR MT
    The shifting issue is squashed with an MT. Just sayin
    Junkhead and shakerhood like this.
  12. Jul 17, 2019 at 7:51 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I tried premium for a few tanks. Didn’t notice a difference in power or mileage. Driving a second gen V6 auto trans.
  13. Jul 17, 2019 at 8:07 PM
    doannutglaze
    doannutglaze Well-Known Member
    2016 MGM Tacoma TRD Sport
    The Costco around here carries 86 and 91. Would 86 be ok since no 87?
  14. Jul 17, 2019 at 8:13 PM
    skierd
    David
    Fairbanks, AK
    Assuming you live at high altitude? Then yes 86 will be fine.
    Good for you. This is the 3rd gen forum.
  15. Jul 17, 2019 at 8:19 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    I run ethanol free 87 and 90 depending where I fill up. I get about 1-2 mpg better than the corn mix ethanol stuff. More BTU’s when there isn’t ethanol in the fuel, so it scientifically makes sense. I started running it a few years ago as I know how even 10% ethanol blends can kill lawn equipment and motorcycles. Worth a few bucks more per fill up to avoid any long term issues.
    :anonymous::crapstorm:
    PRE-K likes this.
  16. Jul 17, 2019 at 8:22 PM
    sunchip89
    sunchip89 Well-Known Member
    For all the people who claim to be engineers on this forum, why hasn't this myth been cast back to the 7th layer of hell?
  17. Jul 17, 2019 at 8:24 PM
    CG256
    CG256 Well-Known Member
    '19 TRD OR
    Has anyone ever tested to see if the ECU is leaving any timing on the table while running the recommended octane? Is that a thing with Toyotas?
    I'm coming over from the VW world and I'm used to these discussions (there its about ethanol blends and injector limits) having datalogs to show IATs, timing and knock sensor info.
  18. Jul 17, 2019 at 8:25 PM
    ksj
    ksj Well-Known Member
    Pacific NW
    2018 Cavalry Blue TRD Pro
    265/70-17 KO2
    Where's the entertainment with that?
  19. Jul 17, 2019 at 8:39 PM
    Mtn Mike
    Mtn Mike Well-Known Member
    Spokane, WA
    2017 TRD OR AC
    I get less pinging with 92 octane. I've never noticed a difference in power or fuel economy. But isn't less pinging a good thing? Is it worth the additional cost of 92 vs 87?
    nomnomtaco likes this.
  20. Jul 17, 2019 at 9:00 PM
    cwdog
    cwdog Well-Known Member
    Asheville, NC
    2017 Tacoma Limited
    Meguiars Ultimate Wax, Rain-X, Dog Bed, Undercover Tonneau Tri-Fold, Debadged.
    Are you high?
    stun gun[QUOTED] likes this.
