92 Pickup LT Plans. Advice?
Discussion in 'Long Travel Suspension' started by H Bomb, Dec 15, 2011.
  1. Dec 15, 2011 at 12:12 AM
    H Bomb
    H Bomb [OP] Well-Known Member
    SAS'd 92 Pickup/08 SR5 Tacoma
    I bought a 92 sr5 4x4 pickup specifically to build into a long travel off road rig. (Currently I have lift shackles in the rear and the torsion bars cranked in the front so that I can fit 33s.) I've done a ton of research, but before I order up parts, I was hoping for some feedback. Here is what I am planning:
    Front:
    Blazeland long travel kit
    Bilstein 5100s
    OME*torsion bars
    TC idler arm
    T100 cv axels
    Hannemann fenders
    Rear:
    Bilsteins
    Block? Add a leaf?*
    wheel spacers to even width with front?
    My questions are:
    1. Anything incorrect about the front?*
    2. What's the best route to go with the rear? As you can see I'm undecided on that part...*
    Thanks for any input or advice!
  2. Dec 15, 2011 at 8:07 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    You will want to do a spring under set up in the rear. I currently have an add a leaf and it does not help at all lol, you wont be able to really use your front LT if the back is not LT too. What are you looking at for a total budget?
  3. Dec 15, 2011 at 8:14 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
  4. Dec 15, 2011 at 8:35 AM
    H Bomb
    Ok. That's pretty much what I am wondering. I was hoping that the leaf springs would be sufficient, but I didn't know...
    As far as budget goes... With the set up I have listed, I'll be spending a little under 2k. I'd be willing to spend about he same on the rear. I bought the truck so that I would have something fun to spend my money on... So I'll throw money at it until it is done. It just might take a while.
  5. Dec 15, 2011 at 8:38 AM
    H Bomb
  6. Dec 15, 2011 at 9:21 AM
    elblako91
    elblako91 Well-Known Member
    Blake
    Lubbock/Houston/Katy
    1992 Toyo Pickup
  7. Dec 15, 2011 at 9:24 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    don't waste your money on the blazeland kit
    go with TC or JD fab torsion bar kit if you are set on keeping torsion bars
  8. Dec 15, 2011 at 9:36 AM
    H Bomb
  9. Dec 15, 2011 at 9:38 AM
    H Bomb
    I looked into the TC kits. I'll check out JD fab now. Hadn't come across them yet. I have heard some mixed things about the Blazeland kit, but I haven't heard any specifics on them not performing well.
  10. Dec 15, 2011 at 9:39 AM
    elblako91
    Blake
    1992 Toyo Pickup
    blazeland<total chaos<JD fab
    Just depends on your budget
  11. Dec 15, 2011 at 9:47 AM
    H Bomb
    Good to know! I was looking at the Total Chaos stuff, because I have heard nothing but good things. I just didn't know if the extra cost was actually worth it. I guess, as with anything else, you get what you pay for...
  12. Dec 17, 2011 at 6:17 PM
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    The real question is what do you plan on doing with the truck? You live in E Washington, what kind of trails will you be on?
  13. Dec 18, 2011 at 9:55 AM
    H Bomb
    I live in southeastern Washington, which is desert. So, I will be using the truck in the sand.
  14. Dec 18, 2011 at 10:08 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    you should invest in rear LT first. No blocks. If you want to save money, wait to buy used off the forums.
  15. Dec 18, 2011 at 11:00 AM
    H Bomb
    Yeah, after getting some awesome advice from guys on here, my plans have changed a bit. I'll probably go with a total chaos front, king shocks, and the giant motorsports rear with a bed cage. What are the advantages to doing the rear first rather than the front?
  16. Dec 18, 2011 at 11:35 AM
    Sunner
    Sunner Well-Known Member
    The rear wont keep up with the front and you'll just bounce off the trail, theres desert in Washington??
  17. Dec 18, 2011 at 4:37 PM
    H Bomb
    Haha...yeah, Washington has desert. It's all sagebrush and sand here!
    I had been planning on doing the front first, because I dont know how long I should leave my torsion bars cranked...
    I hope to get both the front and back done around the same time though.
  18. Dec 18, 2011 at 6:15 PM
    Sunner
    Hmph, that is pretty cool, you have desert eco system and probably with out the heat Cali deserts have :rolleyes:. I was considering LT for about an entire hour one night before deciding it is going to be too much cost and headache from me and that was one of the points I ran across alot, to go LT in the rear first if you are serious about it, hopefully you get both done together as you plan, goodluck with the build.
  19. Dec 18, 2011 at 8:13 PM
    ColesDirtyYota
    ColesDirtyYota Well-Known Member
    Cole
    San Diego
    Dezert Built
    Camburg LT Icon 2.5" x 9" coilovers Radflo 2.0" Bumpstops Radflo 2.5" x 16" tripple- Bypasses Deaver F67 Race Pack Richer Racing 12" shackles Full bedcage Full 2" cab cage Tube bumper Solid motor mounts Total Chaos spindle Gussets RR gusseted UCA mounts Total Chaos poly urethane Steering kit T100 axle 4:88's/ Locker AFE dry air intake BA Muffler Trimmed the Throttle Body Fiberwerx 05+ clip Fiberwerx 8" bedsides Full JL speakers/ deck/ sub Rigid Industry 30" LED bar ORW LED amber lights/ brake lights Kenwood Race Radio HF jack with custom skid plat
    i'd go with the TC caddy 2 kit and a deaver f67 pack out back, 8nch coilovers up front with bumpstops and 16" smooth or tripply bypasses out back on 12" shackles. Your truck will be hauling once u dial ur shocks in and be tons of fun
  20. Dec 19, 2011 at 6:07 PM
    H Bomb
    If I keep the torsion bars, rather than switching to coil overs, will I regret it? How much of a difference do they make?
