93 toyota pickup
Discussion in '1st Gen. Tacomas (1995-2004)' started by houndsmen, Feb 25, 2010.
  1. Feb 25, 2010 at 3:05 PM
    houndsmen
    houndsmen [OP] Well-Known Member
    i have a 93 yota and i recently put a new computer in it. it ran fine for about 3 weeks.... then it started running slugish again. its almost like its under water... it just doesnt have the power. its not like its missing? i put new plugs and wires fuel filter and pump. it starts perfectly fine it just doesnt run the way it did 3 weeks ago? do you guys know what could be wrong with it???
  2. Feb 25, 2010 at 3:13 PM
    TexasIslandBoy
    TexasIslandBoy THE RED DRAGON!!
    Andrew
    South Texas. SPI
    07' trd offroad 4X4 (For Sale)
    pro comp 6inch lift 35'' tires moto 950's radfo coilovers magnaflow exhaust 5/16" front skidplate usa spec ipod interface tree pin strip mod dry drop in filter full size BFG KM2 spare
    does it have a MAF sensor it might have gone out
  3. Feb 25, 2010 at 3:26 PM
    slickyd
    slickyd Well-Known Member
    David
    Talladega, AL
    03 PreRunner SR5
    Sorry can't help you but my dad had a 93 pickup it was the best truck I think I had ever drove. I loved that truck.
  4. Feb 25, 2010 at 3:40 PM
    houndsmen
    i think it does have one??? ill have to check??
    someone else said maybe fuel injectors???
    thanx
  5. Feb 25, 2010 at 3:42 PM
    TexasIslandBoy
    Andrew
    South Texas. SPI
    i think you can get the MAF tested
  6. Feb 25, 2010 at 3:44 PM
    houndsmen
    where do they test them?
    what exactly is the maf???
  7. Feb 25, 2010 at 3:47 PM
    crittergitter
    crittergitter Proud to be Canadian Navy
    Stu
    Shearwater, NS
    '06 Tacoma 4WD Double Cab
    Bugger, skid plate, colour coded cap, bed mat, AFE Air Filter, Rear diff breather mod, Chirp on door lock;unlock, ABS mod, Weathertechs front and rear, 60" Hi-lift jack, LED light mod in rear bed, 12V accessory in bed, n more stuff.
    It is the mass air flow sensor. Could also be a weak fuel pump perhaps.
  8. Feb 25, 2010 at 3:50 PM
    houndsmen
    oh ok!
    what do you think about fuel injectors?
    if it was a weak fuel pump do you think it would give trouble starting at all???
  9. Feb 25, 2010 at 4:03 PM
    TexasIslandBoy
    Andrew
    South Texas. SPI
    i have no clue man
