93000 miles, ATF drain and fill or full flush?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12taco12, Sep 3, 2017.
  1. Sep 4, 2017 at 6:18 PM
    12taco12
    12taco12 [OP] Well-Known Member
    rochester NY
    2012 TX Pro
    Billy 5100s OME 886 Billy remote resi 5125 rear General hd packs TImbren superbumps/flipkit Pelfrey steel full hoop front SOS bolt on sliders Baja squadron amber fogs Baja 20" bar Aux fuse panel and switches custom 10 sub box double din
    well i bought it w 89k on it so its not really me waiting to long and i don't think amsoil is a "boutique" fluid
  2. Sep 4, 2017 at 7:39 PM
    Clearwater Bill
    Billy
    Largo Florida
    If you can't buy it OTC practically anywhere that sells basic auto parts and lubricants in N America, it's boutique.
    The plan for multiple drain/fills is a good one. Quite likely 2 or maybe 3 times will have it in great shape.
    Quite doubtful you'll feel any differences in behavior, but that's good. And you'll know it's got plenty of fresh.
    Your '12 has a temp output for the trans. A scanguage II would be a good investment for many things, including monitoring of trans temps. Important to know if you tow or off road very much.
    Lord Helmet likes this.
  3. Sep 5, 2017 at 3:22 AM
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    Good to know, I could have sworn it was rtv. I've already done four drain/fills though, so I doubt I'll need to remove it anytime soon.
  4. Sep 5, 2017 at 3:25 AM
    80schild
    Chad
    Flori-Bama
    All three of my trucks shift perfect after doing this. Driving about 30 miles between each one should have the fluid good and circulated.
  5. Sep 5, 2017 at 3:32 AM
    doorsidedown
    doorsidedown Well-Known Member
    I flushed mine at 60k and did drain and fill every 30k after that. Never had any issues. The flush is expensive af though.
  6. Apr 2, 2020 at 8:36 PM
    Hank Heel
    Hank Heel Well-Known Member
    WA
    Old thread I know.
    Is there no harm in mixing ws/non synthetic with say valvoline - a synthetic?
  7. Apr 2, 2020 at 9:59 PM
    bordinco90
    bordinco90 Well-Known Member
    SW Louisiana
    2008 Desert Sand Mica Tacoma Prerunner DCSB
    18 inch Black rims with 265/65/18 AT tires. Bilstein 5100 shocks. Black Halo Headlights and Black LED taillights. Window Tint. Black Aftermarket Grille.
    I did a full flush at 160k through my local Toyota Dealership. Mine was shifting a little rough into 2nd gear and overdrive. After the flush it shifts way better now. It was pricey as to be expected going through the stealership (about $400), but to me it was worth it.
  8. Apr 3, 2020 at 7:47 AM
    MtnMan307
    MtnMan307 Well-Known Member
    Aurora, Colorado
    2010 DCSB TRD OR, 2017 Prius 4 Touring Lyft Car
    Weathertech floor mats, Bilstein 5100s front/rear, TSB leaf springs, Pioneer head unit, Mini D2S headlight retrofit.
    I did a full flush a few weeks ago at 152k miles. Valvoline Maxlife full synthetic and a Wix filter kit. It shifts a lot better and even idles and runs better than before.
    It should be good to go another 50-60k. IMO it’s well worth the money and effort.
  9. Apr 3, 2020 at 12:42 PM
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    those stories are mostly just that, urban folklore like the vanishing hitchhiker or razor blades in apples. New fluid is good
    gasgasman and MtnMan307 like this.
  10. Apr 3, 2020 at 5:44 PM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    I just flushed my 2015 with 88,000 miles. I used Maxlife and the following screen filter and gasket kit:
    https://www.amazon.com/gp/product/B07M6WH9JR/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
    The truck shifts great and I’m very happy I did it. I ended up using 16 quarts of MaxLife, overkill but i recently bought the truck and wanted to make sure that I did a complete flush, plus I bought gallon jugs and wanted to do more than just 12 quarts. I flushed/exchanged 2 quarts at a time. I had my wife start and stop the truck. Very easy process.
    I’ve done pan drops followed by a flush and fluid exchange on all my vehicles in the past after a pan drop, never had a problem.
    hoffengineering and MtnMan307 like this.
  11. Apr 3, 2020 at 7:01 PM
    MtnMan307
    Aurora, Colorado
    That kit looks just like the Wix one that I used from Amazon.
  12. Apr 3, 2020 at 7:39 PM
    Micbt25
    TM
    It was a good kit, I like that it had a rubber or rubber-like gasket instead of a cork gasket as there’s a chance that the cork could crack in the box if it’s folded over to many times. A lot of folks say it’s not worth changing out the mesh filter, but why not, you need a new gasket if you do a pan drop and these kits are about the same price of just ordering a gasket. Also, when I removed the filter a good amount of fluid dropped out of the valve body.
    MtnMan307[QUOTED] likes this.
