94 toyota pick up
Discussion in 'Toyota Trucks & SUVs' started by momofboys, Jan 7, 2019.
  1. Jan 7, 2019 at 12:56 PM
    momofboys
    momofboys [OP] New Member
    Guess this may not be a Tacoma since it has no model except pick up.
    Problem is has leaking pop up moon roof. believed to be factory but cant find info on it.. have it compleatly sealed with gorilla tape but still some leaking from hindges..
    What could it be from? my next step is to possible tape up the front windshild.
  2. Jan 7, 2019 at 12:59 PM
    ripcalifornia
    ripcalifornia Trok
    Cal (Kyle)
    HB CA
    2014 AC
    patches
    Welcome to TW, not sure about the roof but I guarantee someone on here can help you out. Good luck!
    momofboys[OP] likes this.
  3. Jan 16, 2019 at 7:38 PM
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
    Yes, that is a Pickup. What model, an SR5? the SR5 was top of the line back then, so a moonroof is possible. Is it a hand cranked moonroof? If not, then it may very well be aftermarket. Gorilla tape will not completely seal it, so it could be the tape. If its the windshield, often it will run down the inside and drip from the front of the firewall area onto the floorboard.
  4. Jan 19, 2019 at 11:53 AM
    momofboys
    So i have put a weather proof plastic over it with clear waterproof tape. Also i have taped up a few spots on the windshield that looked to may be part of the problem. So far it is not leaking at all as long as all areas on sealed off.
    Riding Dirty likes this.
  5. Jan 25, 2019 at 7:54 PM
    Riding Dirty
    PlastiDip
    to narrow it down, remove the tape from the windshield, and see if you get any more leaks. or vice-versa. they you can hopefully pinpoint it better. good luck!
  6. Jan 25, 2019 at 7:59 PM
    Artruck
    Artruck Well-Known Member
    Lawrence, KS
    '09 Super Basic
    If it’s factory, there is most likely a rubber drain line from the roof down one pillar to the door area or the engine bay. That might be clogged up. You can blow it out with compressed air. That’s a place to start.
  7. Jan 25, 2019 at 8:18 PM
    momofboys
    I searched all around the rubber seal and could not find anything, but may have not pulled it apart far enough to check. It has some cracking so was a little worried of pulling to much and it cracks more.. Not something I want to put a whole lot of money into yet since i just got new lights and working on the tail lights. the important legal road things..
