95’Tacoma Mid Travel
Discussion in '1st Gen. Tacomas (1995-2004)' started by joev22, Feb 5, 2025.
  1. Feb 5, 2025 at 6:41 PM
    joev22
    joev22 [OP] New Member
    Joseph
    95’Tacoma Pickup 4x4 SR5 2.7
    Who makes a uniball mid travel setup for a 95’ Tacoma? Seeing mostly 96+
  2. Feb 5, 2025 at 6:42 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Is it a Tacoma or a pickup?
    joev22[QUOTED][OP] likes this.
  3. Feb 6, 2025 at 8:30 AM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    If you have a 95 Tacoma (not 95 Pickup), then all the front suspension for 96-04 fit. For rear suspension, 95-97 have different leaf packs than 98-04. The 95-97 leafs are shorter and are not interchangable with 98-04 without cutting and rewelding the leaf spring hangers.
    The reason for the date discrepancy is that Toyota sold the Toyota Pickup through the beginning of the 95 model year, and mid year of 1995 released the '95.5 Tacoma.
    Many companies are either ignorant of the existence of '95 Tacomas, or just deliberately refer to all 1st gen Tacomas as 96-04 to avoid confusion with '95 Toyota Pickups.
    Either way, for 99% of things if it says 96-04 it will fit your 95 Tacoma.
    joev22[OP] likes this.
  4. Feb 6, 2025 at 10:23 AM
    joev22
    Joseph
    Ok thank you so pickup is basically 95.5 and most of the uppers im looking at is 96-04 which is 99% going to fit
  5. Feb 6, 2025 at 10:49 AM
    time623
    James
    AZ
    1995 Toyota Pickup refers to the predecessor to the Tacoma, an entirely different truck, its model name was Pickup (like Tacoma is the current model name). So avoid using the term Pickup in describing your '95 Tacoma or else you're just going to confuse everybody.
    In general, every single time you see 96-04 it will fit a 95.5 Tacoma.
  6. Feb 6, 2025 at 3:05 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    treyus30 and joev22[OP] like this.
  7. Feb 6, 2025 at 3:16 PM
    02hilux
    Planet: EARTH
    Easy question will be, where’s s gas door located? Driver side will be a Tacoma and passenger side will be a pickup.
  8. Feb 6, 2025 at 4:36 PM
    joev22
    Joseph
    Tacoma
    time623 likes this.
  9. Feb 6, 2025 at 5:00 PM
    JKO1998
    Utah
    Sounds like all you need now is a solid google search
