95 2.7L p0125 need help fast
Discussion in 'Performance and Tuning' started by Texoma, Aug 27, 2015.
  1. Aug 27, 2015 at 7:21 AM
    Texoma
    Texoma [OP] IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    So my sons truck is throwing a p0125 code on a 95 2.7L, this is after he replaced the entire exhaust system with walker exhaust from rockauto. Manifold, down pipe, cat, muffler, and tail. He also replaced both o2 sensors as well. After he fired it up and test drove, it came with the p0125. From reading about that code, it is the B1S1 that is failing. After checking voltage and resistance and ground, we are at wits end to what the issue is. Any input on what to look for or what to do would be greatly appreciated as he needs to run it through inspection by the end of the month. Thanks again.
  2. Aug 27, 2015 at 7:24 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    And a pic just to make it fun
    C__Data_Users_DefApps_AppData_INTERNETEXPLORER_Temp_Saved Images_IMG_1619.jpg
  3. Aug 29, 2015 at 8:43 AM
    BamaToy1997
    Bill
    Navarre, FL
    P0125 is insufficient coolant temp for closed loop operation. This typically means that the engine is not getting to operating temp quickly enough. Not always, but usually this is due to a bad thermostat that is stuck open.
    Texoma[OP] likes this.
  4. Aug 30, 2015 at 2:12 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Everything I have read says the b1s1 o2 sensor is the culprit for the p0125 code, but, thermostats are cheap, and will give it a shot
