95.5 and 96 3.4 tacoma TURBO problem!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by GioGuitarDude, Sep 11, 2013.
  1. Sep 24, 2013 at 10:46 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Hate to break it to you..but the URD piggy back can't run 6 additonal injectors..you'll still need the Map ECU
  2. Sep 24, 2013 at 11:13 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
  3. Sep 25, 2013 at 6:38 AM
    GioGuitarDude
    GioGuitarDude [OP] Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    Yeah I noticed that. It wasn't very clear but it specifically says "It knows exactly what 'injector' (singular) you're using". I wanted to go the mapecu3 route from the beginning but I got all twitterpated on the deal I was given on that stuff. Thanks for letting me know.
    On a side note all my turbo stuff arrives today so I should have a wee boost by Saturday. Fuel and electronic stuff is going to be dealt with next Friday.
  4. Sep 25, 2013 at 7:13 AM
    GioGuitarDude
    Gio
    Cold air intake
    Yeah I'm fabricating everything up myself so with the addition of a dependent oiling system (more reliable) and I'm right under $900. I could have spent $700 if I would have used the engine oil.
  5. Sep 25, 2013 at 7:25 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    the URD controller will run 6 injectors no prob. But you won't be able to to use the Turbo Port injector rail with it.
  6. Sep 25, 2013 at 9:11 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Nice. If anything, you can always look at the CXracing's kit for idea's.
    I was piecing together some stuff last night and got this (Monte, let me know if Im missing anything):
    -CXracing turbo kit ($980): http://www.cxracing.com/mm5/merchan...roduct_Code=TRB-KIT-5VZFE-NO-IC&Category_Code=
    -IC ($100-$250): http://www.cxracing.com/mm5/merchan...TF-KIT250-SET-BOV009-BLS-6&Category_Code=ICDK (something like this, may need additional plumbing and some help fabbing the intake)
    - Tunner/Fuel upgrade ($1300, 255L pump and 420cc injectors, Iridium plugs):
    http://www.tokensolutions.net/products/TS-Toyota-5VZ%2dFE-Supercharger-and-turbo-management-kit.html - Couldnt find a good deal on injectors anywhere and it was actually cheaper to get the URD fuel upgrade kit than 6 injectors from what I could find.
    Total is ~$2500-3000 depending on shipping. About what you would pay for a brand new TRD SC (not including the 7th injector kit)
  7. Sep 25, 2013 at 9:34 AM
    GioGuitarDude
    Gio
    Cold air intake
    I downloaded gadgets PDF installation file for the AIC and it has an application specifically for the turbo port fueler.
    And the one I'm trying to buy from him came with the TPF.
  8. Sep 25, 2013 at 2:41 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    This would be a killer set up.
    Don't forget you need to add in custom exhaust and even tho the IC kit comes with tubing, it'll probably have to be modifed a tad at some point.
    But id run all that.
  9. Sep 25, 2013 at 5:52 PM
    trdtoy
    trdtoy Well-Known Member
    North Carolina
    02 sr5 4x4 auto v6 turbo (sold)
    Turbo with supporting mods and tranny to hold power.
    Just be sure piping where maf sensor is located is same diameter as oem or as close as possible to make tuning easier. Also be sure no bends or bov near maf. Be sure bov is in front of maf closer to turbo as well. You may need a flow straightener before maf if you run into tuning issues. I had a turbo 5vz so I will do my best to help you through this with parts you are using.....
  10. Sep 25, 2013 at 7:25 PM
    GioGuitarDude
    Gio
    Cold air intake
    I appreciate it. I'm going to have the maf as close to the throttle blade as possible and ill keep the BOV thing in mind. I got a 3" BOV assembly but I'm using 2" charge pipes up to at least the wheel well so ill have to tinker around with the location. I've seen 5vzs with it 6" away from the maf that run fine, but I'm in it for reliability and performance, not just speed. Got the t4 snail today and I'm getting the last bit of my aluminumized exhaust and charge pipe bends tomorrow so I'm going to hit it hard after work. Believe it or not but I'm going to be using ABS tubing for the charge pipes from the start of the cab to the BOV :)
    A few guys I've checked into are still boosting with it 3 and 4 years later.
  11. Sep 25, 2013 at 8:25 PM
    DHwreckage
    DHwreckage Well-Known Member
    Boulder, CO
    Moby Dick (FZJ-80)
  12. Sep 25, 2013 at 10:06 PM
    trdtoy
    North Carolina
    Do not place maf close to throttle body as it can create turbulence as well. I would stay 6-8" from it. Also be sure piping is all close to same size as oem or tuning may be difficult. It is hard enough as it is to tune a turbo motor. Also try to have a long straight section before maf and/or air straightener before maf in piping. Be sure you have a way to tune closed loop vs just open loop for happy motor and better results. What is abs tubing? Take this slow man and ask questions so you do not waste your time and/or money.....
  13. Sep 26, 2013 at 4:33 AM
    GioGuitarDude
    Gio
    Cold air intake
    Its that black PVC tubing you see at home depot. Its made out of a polymer that's very strong like the furniture on a military m16.
  14. Sep 26, 2013 at 6:15 AM
    GioGuitarDude
    Gio
    Cold air intake
    Sweet. I'm in dtown BTW.
  15. Sep 26, 2013 at 7:29 AM
    #35
    DHwreckage
    Boulder, CO
    Moby Dick (FZJ-80)
    Wait what your in Denver?
  16. Sep 26, 2013 at 8:14 AM
    #36
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Thanks man, I think my budget i maxed so exhaust will stay... (well, it was probably maxed at $500). If I deploy or get an IA this next set of orders, chances are, Ill go for it. Gonna have to buy my wife a Van though... :p
    That said, awaiting results from OP :popcorn:
  17. Sep 26, 2013 at 10:31 AM
    #37
    GioGuitarDude
    Gio
    Cold air intake
    Technically Thornton. You should consider adding additional injectors instead of replacing your primaries with bigger ones because there has been known issues with running too rich and throwing codes when you get too big on the primaries even with a nice fuel controler. That's why I'm getting the URD turbo port fueler. $200 for the port fueler, $65x6 (or cheaper used) for the extra injectors and $100 for the 255l fuel pump. So $700 plus whatever piggyback you want to use and you have the option of driving completely stock until you get your foot in it (since the primary injectors are still stock). I'm not sure how much the tokensolutions piggy is but I'm sure you would come out at or under the kit you want to get.
  18. Sep 26, 2013 at 10:56 AM
    #38
    DHwreckage
    Boulder, CO
    Moby Dick (FZJ-80)
    Well if you need help this weekend let me know would love to see this turbo setup!
  19. Sep 27, 2013 at 6:35 AM
    #39
    GioGuitarDude
    Gio
    Cold air intake
    Leaving on a business trip on Sunday morning so I'm going to try to knock everything out today and tomorrow. We pass through boulder a lot to target practice in the boulder mountains, so maybe ill hit you up so we can chit chat and you can check out the setup. I'm really making an effort to be a guinea pig and spread as much info on DYI turbo tacomas as I can because the info I finally got took so much effort and time to get.
    On a side note I got the my muffler cut (holy crap going to work was loud this morning) and the exhaust flange welded so I should at least have the turbo mounted and oil lines connected with no charge pipes (yet) before dark today. Charge pipes and a dyno tune(maybe) will come tomorrow.
  20. Sep 27, 2013 at 8:13 AM
    #40
    GioGuitarDude
    Gio
    Cold air intake
    I didn't expect it, but I guess this is going to double as a build thread. I wish I had enough time to figure out how to change the title...:eek:
