95-97 Tacoma Gauge Cluster Swap Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ikeepthepeace, Nov 20, 2019.
  1. Nov 20, 2019 at 4:34 PM
    Ikeepthepeace
    Ikeepthepeace [OP] Active Member
    Mason
    Oahu, Hawaii
    2006 Tacoma double cab long bed
    2 inch level
    Aloha Tacoma owners,
    I have a 95.5 Tacoma 3.4 Automatic that has a gauge cluster without a tachometer. I want to install one that has a tachometer. I have seen a previous thread about someone doing it on a 98. But I want to know is can I use any cluster from a gen 1 Tacoma for my 95.5? and if so is it just plug play or do I need to run something to my engine to get a working tachometer and trip meter? I really appreciate any help!
    Mahalo
  2. Nov 20, 2019 at 5:13 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    1995-1997 has a mechanical cable driven VSS.
    1998-2004 has an electronic VSS.
    Therefore you need to find a cluster from a 1995-1997 truck with the cable driven cluster. You cannot use a cluster from 1998-2004 as they are electronic.
  3. Nov 20, 2019 at 5:29 PM
    Ikeepthepeace
    Mason
    Oahu, Hawaii
    2 inch level
    Ok sweet, I have found one from a 96, so is it just plug and play? or do I need something else to get the readings from the trip meter and the tachometer?
  4. Nov 20, 2019 at 5:35 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Should be plug-n-play. Just make sure they're both mechanically driven. Pull the cluster out and look for a metal cable.
  5. Nov 20, 2019 at 5:36 PM
    Ikeepthepeace
    Mason
    Oahu, Hawaii
    2 inch level
    Ok will do thanks for your advice
  6. Nov 20, 2019 at 5:37 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Your mileage will obviously be different between clusters. You could probably swap the modules so the correct mileage follows.
  7. Nov 20, 2019 at 5:39 PM
    Ikeepthepeace
    Mason
    Oahu, Hawaii
    2 inch level
    Is it possible to just swap the odometer piece?
  8. Nov 20, 2019 at 5:44 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    It is on 98-04. Unsure of 95-97.
