95 Regular cab w/3.4 V6 is it rare?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kcdub_u, Sep 15, 2010.
  1. Sep 15, 2010 at 1:19 PM
    Kcdub_u
    Kcdub_u [OP] Active Member
    Casey
    Concord,ca
    I am about to pull the trigger on a 1995.5 Tacoma 4x4 (~200k miles) and wanted some quick input. It is a regular cab 5-speed, but it has a 3.4 liter V6.
    Is that common and is that engine reliable?
    What is a fair price? (Blue book is $2500, but tacomas usually go for quite a bit more here in CA) Seller is asking for $3000
    Thanks
  2. Sep 15, 2010 at 1:21 PM
    98tacoma27
    Ben
    Not Beech Creek
    My ex stepdad has one.
  3. Sep 15, 2010 at 1:50 PM
    Kcdub_u
    Casey
    Concord,ca
    Also, is there anything I should be paying close attention to when I go to look at it again?
  4. Sep 15, 2010 at 1:51 PM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    Yes, it is a rare truck. Probably the rarest Tacoma.
  5. Sep 15, 2010 at 3:03 PM
    98tacoma27
    Ben
    Not Beech Creek
    Does CA = Canada or California?
    The frame and the last time the timing belt was changed would be my major concerns
  6. Sep 15, 2010 at 3:10 PM
    Kcdub_u
    Casey
    Concord,ca
    California. The timing belt was last changed at 150,000
  7. Sep 15, 2010 at 3:11 PM
    98tacoma27
    Ben
    Not Beech Creek
    Well, as long as it is mechanically sound, been maintained........I say haggle to get the price you want.
  8. Sep 15, 2010 at 4:11 PM
    yotabeast505
    yotabeast505 The Beast
    David
    NE Hights ABQ NM
    THE BEAST
    here we go. Ford 9" rear after breaking 5 sets of gears in the stock yota 8.8, 5.13 gears with a detroit hard locker, 63" chevy leafs and custom hangers, sky's front spring hanger with sky's extream hysteer and PSC hydro assist ram and PSC pump. welded front spyders in the f-550 front dana 60 with warn hubs, pico brake lines and hoses, elecrtic fan, TRD supercharger with URD 2.1 Pully, URD Map-ECU2 and cage built by me. wide band a/f by inovations, lots and lots more...........
    no not rare down here in NM lots of people have them
  9. Oct 20, 2014 at 11:12 PM
    xcmtb83
    xcmtb83 Well-Known Member
    Iowa
    Do an autotrader.com or cars.com search and you will find out how rare they are compared to other Tacomas. BTW they were only available 95.5-97.
  10. Oct 21, 2014 at 2:50 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    frame,frame,frame.....
    Check the frame for 'internal' rust. This won't be detected from the outside.
    They were known for rusting/rotting from inside out.
  11. Oct 21, 2014 at 5:59 AM
    Terminal4
    Terminal4 Well-Known Member
    South of the Sierras
    2022 DCLB 4WD
    Accutuned Fox suspension, Wildpeaks AT4, Batzmaru
    You lucky sob. Buy it already!
