95 Taco dif lockers
Discussion in '1st Gen. Tacomas (1995-2004)' started by Andrew m, Sep 9, 2022.
  1. Sep 9, 2022 at 3:39 PM
    Andrew m
    Andrew m [OP] Guaco Taco
    Grant
    Tennessee
    95 taco 2.7L manual 4x4 AND MORE!
    6in fab tech lift kit, 6in skyjacker leaf springs rear, fab tech stealth shocks rear, posi front and rear, ring and pinion reduction, warn locking hubs, raptor liner olive green, rear X brace, aftermarket front and rear bumper with led marker lights, 3in bolt on bushwacker fender flairs, 1 1/4 wheel spacers, new energy body bushing and lower and upper control arms bushing, custom glass pack exhaust, pace setter header 4 in 1 full length, K&N air filter, center-force clutch, manual swapped cab, pioneer dmh-1770, jl-audio C1-650 door speakers and tweeters
    Hey guys I’m looking for some e lockers for my taco. It’s 4wd with 4.56 gears in it and used to have full posi in it until on they way back from picking up a bike 700+ miles from home the drain plug in the rear fell out ( no it was not my fault). Anyway the ring and pinion are for sure toast and I’ve been wanting to put a locker in it to make it safer for a while. Any suggestions on e lockers, I don’t mind spending a good chunk of change as long as it’s worth it. Thanks
  2. Sep 9, 2022 at 3:41 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Harrop.
    Abeyancer likes this.
  3. Sep 9, 2022 at 9:22 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    The harrop like mentioned above or find a complete used rear axle out of a trd tacoma.
  4. Sep 9, 2022 at 9:24 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I'd still vote for a good ol fashioned air locker
    Wulf likes this.
  5. Sep 9, 2022 at 9:25 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Harrop over TRD or ARB?
  6. Sep 9, 2022 at 9:26 PM
    Speedytech7
    I don't like the weird self locking and unlocking behavior the harrop has, and the TRD locker is just a weakling. ARB or a Yukon ziplocker would be my vote
    Key-Rei[QUOTED] likes this.
  7. Sep 9, 2022 at 9:30 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Well, the OP said lockers instead of locker so I assumed both front and rear.
    If only rear, whatever the OP desires though an axle housing swap would be the cheapest (and easiest).
    If both front and rear, I'd want to go Harrop.
    Though a ton of people run air and prefer that route.
    Big brain says "while you're in there..." might as well go 40s n tons :burp:
    Key-Rei[QUOTED] and 02hilux like this.
  8. Sep 10, 2022 at 3:42 AM
    Falkor1
    Falkor1 Well-Known Member
    David
    Arizona
    95.5 Tacoma 2.7 4x4
    2,000 Tacoma rear axle with E-Locker.
  9. Sep 10, 2022 at 6:07 AM
    02hilux
    Planet: EARTH
    TJM over ARB.
    If it's between ARB and Harrop, I rather run Harrop over ARB. No stupid compressor taking more space elsewhere. I have buddies running Harrop with 35 and 37 without any issue.
  10. Sep 10, 2022 at 7:55 AM
    Andrew m
    Grant
    Tennessee
    The front and rear were full posi but I figured with the situation that I’m in it would be safer to put a e locker in the rear(it’s still manual locking hubs). As far as price goes, it looks like the air lockers are cheaper but I still need to get a compressor. I like that e locker axle swap but I still have to change the ring and pinion. I wish I could do a axle housing swap which I suppose I can if it has 4.56 gears in it. I appreciate the input
  11. Sep 10, 2022 at 8:16 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You mean you were running lunchbox lockers? Front and rear?
    As for air and electronic, they end up costing about the same in the end. Electric has a higher initial cost for the locker itself, but is offset by the install requirements/prerequisites almost when going with air.
    Why not focus on a selectable locker in the rear since that's where your issue is and address the front at a later point if/when needed?
    whatstcp likes this.
  12. Sep 10, 2022 at 9:49 AM
    Andrew m
    Grant
    Tennessee
    Yeah that was kinda my plan. I think I’ll go with a e locker. Do you guys know of anyone that will put everything together or any rebuild kits that I can get and how difficult it really is to get the backlash set correctly. Thanks
  13. Sep 10, 2022 at 9:51 AM
    Andrew m
    Grant
    Tennessee
    Are the axles in a 95 taco 7.5 ifs?
  14. Sep 10, 2022 at 9:53 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    1995.5 is the first year of the Tacoma.
    All 1st Gen Tacoma's have the same front diff (95.5-04)
  15. Sep 10, 2022 at 10:35 AM
    Andrew m
    Grant
    Tennessee
    My bad, rear axle. Is the rear axle a 7.5 ifs. I only plan on messing with the rear and leaving the front posi. Since it’s manual locking hubs I should be fine
  16. Sep 10, 2022 at 10:37 AM
    Andrew m
    Grant
    Tennessee
    Maybe in the future I will make the front an air locker but for now it’s staying posi
  17. Sep 10, 2022 at 11:30 AM
    02hilux
    Planet: EARTH
    First gen tacoma:
    7.5hp front
    8" elock or 8.4" nonelock
  18. Sep 10, 2022 at 11:57 AM
    Andrew m
    Grant
    Tennessee
    So I should be looking for a 8.4’’ since it didn’t come with an e locker form factory correct?
  19. Sep 10, 2022 at 2:36 PM
    Andrew m
    Grant
    Tennessee
    I just realized what I said. The axle code says it’s a 8” ring gear. It was B03A
  20. Sep 10, 2022 at 10:18 PM
    02hilux
    Planet: EARTH
    IIRC, all first gen came with an 8" elock or 8.4" nonelock. And 8"elock wasn't an option until 98 if memory serve me correctly. Only 4R came with open 8".
