95 Taco lift...Any suggstions?
Discussion in 'New Members' started by evil_gandhi, Oct 12, 2008.
  1. Oct 12, 2008 at 7:52 AM
    evil_gandhi
    evil_gandhi [OP] Member
    Jake
    Northern California
    1995 4x4
    Bilstein 5100's all the way around, fronts @2.5" (highest) setting. Rear leaf springs from a '91 pickup (1.5" lift). Firestone airbag spring helpers. Doug Thorley ceramic coated Tri-Y header. K&N air filter. Tubular steel front bumper.Much more planned!!!
    I have a 95 4x4 tacoma, 2.7, and I think it is a great truck.
    I got a set of bilstein 5100s and used the middle setting when I installed them. Now my front is higher than the rear.
    I have been considering add a leafs or whole new leaf packs.
    My plan was to adjust the struts to the max and use the add a leafs. but that would require readjusting my camber. (any tips on camber adjustment???
    But if anybody has an Idea they want to share with me, I would LOVE to hear it. tell me what has worker and what hasent. I would really apreciate some feedback
    P.s: am not turning it into a crawler so I am not looking for something too extreme (3"-5")
    also does anybody have a recomendation for a performance chip?
    Thanx a bunch
  2. Oct 12, 2008 at 7:55 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to Tacoma WOrld! :D
    There are no performance "chips" that work on the Tacoma. If you have seen the Jet chip and want to buy it, Send me some money, and I will send you a bag of your favorite Doritos. At least that way you will have SOMETHING. For the rear, you should consider getting a new spring pack, as your may be original, and a replacement would give you a quality ride and a nice lift. Also, anytime you lift, you should get an alignment.
