95 Tacoma AC Issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by tupelolathrop, Dec 13, 2023.
  1. Dec 13, 2023 at 2:04 PM
    tupelolathrop
    tupelolathrop [OP] Member
    Tupelo
    Kauai
    1995.5 3.4l V6 Regular Cab
    3" lift ADS Coil overs, SPC UCAs, 4Runner Limited wheels,
    I have a 1995 Tacoma 3.4l V6. I just had the entire AC system replaced and charged by a certified mechanic. When it’s working it works well and blows cold. However, it randomly decides when and when not to stay cold. Usually if I start my truck with the AC on it’ll stay cold but if I turn the AC on once it’s already running it won’t get cold. I’m not very educated on the AC systems in these trucks. If anyone has any advice it would be much appreciated. Thanks!
  2. Dec 13, 2023 at 2:32 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    Sounds like it wasn't charged correctly or perhaps your aux fan is not firing up.
  3. Dec 13, 2023 at 2:36 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    A lot of times that means it didnt get evacuated correctly...
    if its not electronic related......my guess is air in the system....
    it happens...
    It would cost me 2 cans from wally world to test that theory......$20....
    makes you wonder if they got the oil right.....too much or too little might do the same....but just guessing...a reach....
    simplest thing is go check all the wiring connections first....before anything else..
    always assume the simplest...easiest to fix first...
    Do they have a dye that can be put in the freon???
    If so that's what I'd do after eliminating everything else and attempting to recharge...
    wouldnt just blindly recharge it....
  4. Dec 13, 2023 at 2:54 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Is your recirculation setting turned on in both instances?
    Without a set of gauges to see whats going on in the system we're all just guessing. I recommend taking it back to your guy to look at it
