95 Tacoma front wheel bearing
Discussion in '1st Gen. Tacomas (1995-2004)' started by jacoboe21, Jan 8, 2017.
  1. Jan 8, 2017 at 3:29 PM
    jacoboe21
    jacoboe21 [OP] Active Member
    Jacob
    Tacoma 3rzfe
    I have a 95 taco 4x4 with manual locking hubs and the passenger front wheel has tons of play. I removed the locking hub, brake rotor and the spindle is off. How do I remove the bearing? It does not have abs.
  2. Jan 9, 2017 at 1:11 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    With a massive 40 ton press i believe...they are not easy, you'll have to take it somewhere.
  3. Jan 9, 2017 at 10:42 AM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    Sounds like I have the exact same truck, I did mine about 3yrs ago, you'll need a press, I justified myself buying one to keep for future use. I bought the 20 ton at Harbor Freight, worked fine. I got it when they had a good sale going on,, $120 or 130, can't remember. I also have the Taco factory manual.
    If you want I'll try and copy the procedure to the post if you're interested.
