`95 Tacoma, Installed `91 rear end. sensor help.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Caledonia, Apr 30, 2013.
  1. Apr 30, 2013 at 8:18 AM
    Caledonia
    Caledonia [OP] New Member
    NB, Canada
    '95 Tacoma SR5
    Hi,
    I swapped out my Bad Rear end out of my `95 2.7L Tacoma with one from `91 2.4L 4x4 Tacoma.
    on my `95 tacoma there are two rear sensors mounted near the rear hubs
    on the `91 there is only one sensor in the middle of the dif on top of the pumpkin.
    Can I just wire in the single harness from the '91 by splicing it into the electrical from the 2 sensors on the `95?
    assuming the 2 sensors on the axles of the '95 differential are the same kind of sensor on the '91 differential...
