'95 Tacoma issue
Discussion in 'Technical Chat' started by gloria, Jun 19, 2012.
  1. Jun 19, 2012 at 2:48 PM
    gloria
    gloria [OP] New Member
    Upstate NY
    1995 Tacoma
    I have a 1995 Tacoma with 100,000 miles, I've only had it for about 8000 miles. It started out running great then all of a sudden it died and needed a fuel pump. After that it was fine for a while then died again, leading to the discovery of a broken wire. It appears from the number of splices in this wire the truck is now on fuel pump number four. It is running horribly. We have the idle turned up to prevent stalling. When idling if I put it in neutral it is okay unless I turn on the AC, then it coughs and sputters and stalls. If I leave it in drive while at a light it surges and coughs and sputters and stalls. Sometimes it almost feels like one of those bucking broncos you used to put a quarter in to ride. I put in a can of carbuerator cleaner and it ran okay during the entire tank of gas but as soon as I refilled the tank...same problem.
    Any ideas?
  2. Jun 19, 2012 at 3:01 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    replace the whole wire maybe? get rid of the root of the problem
  3. Jun 19, 2012 at 3:02 PM
    Stubbs95tacoma
    Stubbs95tacoma Well-Known Member
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    My 95 works fine... Must be the wire
  4. Jun 20, 2012 at 5:30 PM
    gloria
    Upstate NY
    1995 Tacoma
    The broken wire was replaced.
