95 Tacoma overheating, need help with troubleshooting
Discussion in '1st Gen. Tacomas (1995-2004)' started by toyotapetr, Aug 6, 2014.
  1. Aug 6, 2014 at 6:47 PM
    toyotapetr
    toyotapetr [OP] Member
    V6 5VZ-FE Engine
    friend bought with 244 miles, automatic 4wd, slightly overheats in long hills and heat….
    discovered that engine was recently rebuilt with new heads, gaskets, water pump, timing belt, valve covers, etc.
    Radiator looks recent….
    friend replaced cooling fan clutch and thermostat, didn't help
    i have checked compression, 205-215, excellent, spark plugs has right color, ran engine even without thermostat, it still going towards red in hills….
    truck seems to have little less of power than other tacomas….
    WHAT YOU WILL CHECK NEXT ?
    Thanks
  2. Aug 6, 2014 at 6:49 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Was the radiator flushed with the water pump or just drained?
    With the age and mileage the radiator may be partially clogged, and may need to be replaced.
  3. Aug 7, 2014 at 8:03 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    It sounds like a clogged radiator if it's overheating at a good speed.
  4. Aug 11, 2014 at 10:30 AM
    toyotapetr
