95 tacoma running rough
Discussion in '1st Gen. Tacomas (1995-2004)' started by Colehbrown, Jan 26, 2020.
  1. Jan 26, 2020 at 9:52 PM
    Colehbrown
    Colehbrown [OP] New Member
    Cole
    1995 Toyota Tacoma
    My 95 tacoma 4cyl 2.4L when I drive it the engine revs up and down when driving as if its losing power. Its like its cutting out. WHAT HAPPENED:I took it off roading sunk it in a mudhole.(sunk up to the speaker in the door not near the computer or even close to the steering wheel) I checked everything I had a bad starter.WHAT I REPLACED: replaced starter everything was fine check engine light came on checked the check engine light: bad o2 sensor replaced it now the check engine light is off. then I bought a new truck (not because it was running bad) it sat for about 1 month I went and fired it up and it died out of nowhere. I couldn't figure out what was wrong. I replaced the TPS (throttle position sensor) still ran bad. Then I replaced the MAF (mass airflow sensor) checked the air filter checked for spark all good. it still runs bad. So I took it to a mechanic all he did was replace the alternator and put a new battery in it. He said it was good to go it wasn't took it home and parked it came back the same day and it would die. Took it back he replaced some o2 sensors and then it died in the middle of an intersection I had to pump the gas pedal and keep trying the starter for about 30 seconds. Then i had the fuel filter replaced. He then told me the computer could be the problem I removed it and there was no corrosion and it is clean. I don't know what to do from here any ideas?
    Taco critter likes this.
  2. Jan 26, 2020 at 9:53 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    Welcome to TW! :hattip::wave:
    det107 and Taco critter like this.
  3. Jan 26, 2020 at 9:53 PM
    PennSilverTaco
    Charlie
  4. Jan 27, 2020 at 7:07 AM
    det107
    det107 Well-Known Member
    Welcome to TW!!
    Hope you get the truck running good before it becomes a millstone around your neck!!
    PennSilverTaco likes this.
  5. Jan 27, 2020 at 9:27 AM
    Morden
    Morden Well-Known Member
    Cali Central Valley
    2002 Tacoma TRD PreRunner
    When was the last time the throttle body was cleaned?
  6. Jan 27, 2020 at 12:34 PM
    zooma-loom
    zooma-loom Well-Known Member
    RIGHT out of sight of SCOTTSDALE, AZ
    1997 Tacoma, Ext Cab, 4x4, 3RZ, A/T, Manual locking hubs
    Motor Mounts. The 4 cylinder motor mounts will go about 60,000 even though they look intact. Trust me as I own a 97 since new and went through the parts change bit & not until I changed the mounts did it run smooth as a sewing machine. I have to change mine every 60,000 and is now part of my Maintenance interval. 277,000 and still going strong.
