95 Tacoma wiper switch faulty intermittent-wipers won't park down too
Discussion in '1st Gen. Tacomas (1995-2004)' started by mtnsdesert, Apr 22, 2020.
  1. Apr 22, 2020 at 6:23 AM
    mtnsdesert
    mtnsdesert [OP] Member
    95 tacoma 4x4 sx
    totally stock except tire size
    Hello Tacoma fans, how many have had this problem? I watched a video on you tube showing a relay replacement will fix it. Dinky relay on the circuit board fixed on the switch. It is no longer available thru Toyota but there is a replacement. My switch doesn't unplug or come strait out like the video or the 2 screws located different, mine are screwed in from the front not the side. Anyone ever try this switch relay replacement and be successful? Thanks for your feedback!
  2. Jan 31, 2024 at 6:55 PM
    Farmboy80
    Farmboy80 Member
    Willamette valley
    95 xra cab tacoma 5vzfe manual
    1.75 lift K&N intake with Injen dry filter w/pre filter
    I have a 95 tacoma that has the same problem.
    I haven't done anything about it yet.
    Hopefully a tacoma nut pipes up and schools us.
    I am also curious about a column upgrade to a later version. Cmon taco brains...help us out.
  3. Jan 31, 2024 at 7:28 PM
    Farmboy80
    Farmboy80 Member
    Willamette valley
    I read that the motor is responsible for going back to home position vs stopping wherever I turn my switch off.
    And that intermittent function is in the switch.
    Anyone know if any other toyota models have the same intermittent switch as the first version of tacoma? (95-97)
    Also, has anyone ever swapped a later version steering column into a 95-97?
  4. Jan 31, 2024 at 7:35 PM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    Hi, Tacoma nut here
    Check out my thread from a couple months ago. It’s a bit of a read but shows the journey I went through to fix that same problem.
    I think my specific problem was a bit weird so you might still need a different solution, but I put as much information as I could which might help you narrow down the specific cause of your problem.
    I linked a lot of other threads in my thread about these wipers as well that you can read through.
    https://www.tacomaworld.com/threads/95-97-windshield-wiper-problems.816622/
    ControlCar and Farmboy80[QUOTED] like this.
  5. Jan 31, 2024 at 7:51 PM
    Farmboy80
    Farmboy80 Member
    Willamette valley
    That's a great thread. Il be referring to that as I'm hunting down my issues. Thanks!
    time623 likes this.
  6. Feb 1, 2024 at 12:21 PM
    Farmboy80
    Farmboy80 Member
    Willamette valley
    Anybody heard of, or have done, a steering column swap to later version column, on a early tacoma?
    Any insight on a S. column weld mod on a 95-97?
    The videos I've watched are not the early version of column. (I think)
